path: root/c/src/lib/libbsp/a29k (follow)
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-115-9/+16
| | | | | | | * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-4/+7
| | | | * startup/Makefile.am: Reformat.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-6/+10
| | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-192-0/+6
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds ramlink romlink.
* 2002-07-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-042-1/+6
| | | | | * wrapup/Makefile.am: Eliminate TMPINSTALL_FILES. Remove $(OBJS) from all-local.
* 2002-06-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-302-8/+4
| | | | * wrapup/Makefile.am: Remove preinstallation of libbsp.a,
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-3/+9
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-288-8/+14
| | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-042-1/+6
| | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-183-11/+22
| | | | | | | * configure.ac: Add RTEMS_BSPOPTS_* for SERIAL_INPUT, HIF_INPUT, SERIAL_OUTPUT, HIF_OUTPUT. * console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT, HIF_INPUT, SERIAL_OUTPUT, HIF_OUTPUT, add #include <bsp.h>.
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-032-7/+5
| | | | * configure.ac: Introduce RTEMS_BSP_CONFIGURE.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-122-0/+57
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-122-55/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-114-0/+14
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-101-0/+5
| | | | | * acinclude.m4: New file. * configure.in: Use RTEMS_BSP_SUBDIR.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-102-2/+12
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-282-1/+5
| | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-2/+7
| | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-05-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-256-9/+28
| | | | | | | | | * include/Makefile.am: Use *_HEADERS instead of *H_FILES, add bspopts.h. * include/.cvsignore: Add bspopts.h. * include/bsp.h: Add bspopts.h. * console/Makefile.am: Use *_HEADERS instead of H_FILES. * configure.in: Add bspopts.h.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-112-1/+5
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-082-5/+5
| | | | * wrapup/Makefile.am: Remove warning missed in shmsupp removal.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-0810-303/+10
| | | | | | | | * Shared memory support removed since it was non-functional. * shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed. * configure.in, Makefile.am, wrapup/Makefile.am: Modified to reflect above.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-094-2/+10
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-024-2/+10
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-0/+7
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-4/+1
| | | | * ChangeLog: Removed incorrectly placed entry.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-012-4/+10
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-274-2/+12
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-252-5/+13
| | | | * ChangeLog: Entry added to wrong file and moved.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-255-4/+21
| | | | | | | | * bsp_specs: Formatting more like other bsp_specs. * include/bsp.h: CPU_CLOCK_RATE_MHZ not a real variable to elimate need for including bsp.h in libcpu. * startup/bspstart.c: Ditto. * wrapup/Makefile.am: Did not list shmdr.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-229-10/+82
| | | | | | | | | | | | * start/crt0.S: Renamed to start/start.S. * start/start.S: Formerly start/crt0.S. * startup/linkcmds: New file. GNU linker script that is not correct for the target board but links programs. * bsp_specs: Use linkcmds. * include/Makefile.am, start/Makefile.am startup/Makefile.am: Now work. * startup/bspstart.c, startup/setvec.c: "#if 0"'ed out references to reoutines in assembly that are in turn "#if 0"'ed out.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-056-0/+10
| | | | | * console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include compile.am.
* Adding ChangeLogs.Joel Sherrill2000-08-102-0/+6
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1210-19/+28
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-138-0/+38
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-082-5/+6
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-2/+0
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Patch rtems-rc-20000118-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-2612-331/+200
| | | | | | | | | | | | | | | | | | | | that converts the a29k to automake. This patch contains * An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS, most code inside them seems to be empty stubs. One file even contains a function called mips_*** which might indicate that this part might contain mips code or the code the initial porter used as template for porting. Unfortunately, I don't know anything about the a29k so I can't comment on the details. * A dummy bsp_specs to libbsp/29k/portsw * An update to the automake files related to the a29k. Note: * This patch is completely untested, because I don't have a toolchain for it. * The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue hits again.
* Patch rtems-rc-20000104-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-102-0/+61
| | | | | | that converts the a29k directory to automake. NOTE: This port is not based on the GNU tools so no one can test it.
* Patch rtems-rc-20000104-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-1011-137/+74
* Fixed path to shared/include/coverhd.h.Joel Sherrill2000-01-031-1/+1
* Now use coverhd.h out of the libbsp/shared directory.Joel Sherrill1999-12-211-1/+1
* Now use shared coverhd.hJoel Sherrill1999-12-211-114/+0
* Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.Joel Sherrill1999-11-304-4/+4
| | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-223-3/+3
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-222-2/+2
* Updated copyright notice.Joel Sherrill1999-11-1711-22/+11
* Minor changes since new Makefile.Joel Sherrill1999-11-161-4/+5
* Added start subdirectory.Joel Sherrill1999-11-161-1/+1
