* configure.in: Remove.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, add
bspopts.h.
* include/.cvsignore: Add bspopts.h.
* include/bsp.h: Add bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of H_FILES.
* wrapup/Makefile.am: Remove warning missed in shmsupp removal.
* Shared memory support removed since it was non-functional.
* shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* configure.in, Makefile.am, wrapup/Makefile.am: Modified to
reflect above.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* ChangeLog: Entry added to wrong file and moved.
* start/crt0.S: Renamed to start/start.S.
* start/start.S: Formerly start/crt0.S.
* startup/linkcmds: New file. GNU linker script that is not
correct for the target board but links programs.
* bsp_specs: Use linkcmds.
* include/Makefile.am, start/Makefile.am startup/Makefile.am:
Now work.
* startup/bspstart.c, startup/setvec.c: "#if 0"'ed out references
to reoutines in assembly that are in turn "#if 0"'ed out.
* console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am.
