* configure.in: Remove.
* acinclude.m4: New file.
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the a29k directory to automake.
NOTE: This port is not based on the GNU tools so no one can test it.
