path: root/c/src/lib/libbsp/a29k/ChangeLog (follow)
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-4/+1
| | | | * ChangeLog: Removed incorrectly placed entry.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-0/+7
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-0/+5
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-251-5/+1
| | | | * ChangeLog: Entry added to wrong file and moved.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-251-0/+8
| | | | | | | | * bsp_specs: Formatting more like other bsp_specs. * include/bsp.h: CPU_CLOCK_RATE_MHZ not a real variable to elimate need for including bsp.h in libcpu. * startup/bspstart.c: Ditto. * wrapup/Makefile.am: Did not list shmdr.
