* include/rtems/libio.h: Add #include <rtems/fs.h>.
Reflect changes due to using rtems/fs.h.
* include/rtems/libio_.h: Reworked.
* include/rtems/libio_.h: Remove set_errno_and_return_minus_one.
* libc/cfsetispeed.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* libc/cfsetospeed.c: Include <rtems/seterr.h>.
* libc/chdir.c: Include <rtems/seterr.h>.
* libc/chmod.c: Include <rtems/seterr.h>.
* libc/chown.c: Include <rtems/seterr.h>.
* libc/chroot.c: Include <rtems/seterr.h>.
* libc/closedir.c: Include <rtems/seterr.h>.
* libc/eval.c: Include <rtems/seterr.h>.
* libc/fchdir.c: Include <rtems/seterr.h>.
* libc/fchmod.c: Include <rtems/seterr.h>.
* libc/fdatasync.c: Include <rtems/seterr.h>.
* libc/fpathconf.c: Include <rtems/seterr.h>.
* libc/fstat.c: Include <rtems/seterr.h>.
* libc/fsync.c: Include <rtems/seterr.h>.
* libc/ftruncate.c: Include <rtems/seterr.h>.
* libc/getdents.c: Include <rtems/seterr.h>.
* libc/ioctl.c: Include <rtems/seterr.h>.
* libc/link.c: Include <rtems/seterr.h>.
* libc/lseek.c: Include <rtems/seterr.h>.
* libc/mknod.c: Include <rtems/seterr.h>.
* libc/open.c: Include <rtems/seterr.h>.
* libc/read.c: Include <rtems/seterr.h>.
* libc/readlink.c: Include <rtems/seterr.h>.
* libc/rmdir.c: Include <rtems/seterr.h>.
* libc/stat.c: Include <rtems/seterr.h>.
* libc/symlink.c: Include <rtems/seterr.h>.
* libc/tcsetattr.c: Include <rtems/seterr.h>.
* libc/telldir.c: Include <rtems/seterr.h>.
* libc/ttyname.c: Include <rtems/seterr.h>.
* libc/ttyname_r.c: Include <rtems/seterr.h>.
* libc/unlink.c: Include <rtems/seterr.h>.
* libc/unmount.c: Include <rtems/seterr.h>.
* libc/utime.c: Include <rtems/seterr.h>.
* libc/write.c: Include <rtems/seterr.h>.
* libc/printk.c: Include rtems/bspIo.h instead of bspIo.h.
* include/Makefile.am: Remove bspIo.h.
* include/bspIo.h: Removed.
* libc/libio.c: Initialize more fields to NULL/0 during initialiation.
* include/rtems/libio_.h: Fix freenode macro so it works for sockets
which do not have the full set of filesystem operations and are
initialized via something other than open().
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs, require automake-1.5
* include/chain.h: Fixed typo.
* include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/sys/Makefile.am: Use = instead of += to setup
NETWORKING_H_FILES and NEWLIB_H_FILES.
* include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX
is defined on GNU/Linux (RedHat 6.2 distribution).
* libc/unixlibc.c: Added stubs for rtems_io_register_name() and
rtems_io_lookup_name() so UNIX port would compile the IO manager
sptest that registers /dev/null.
* include/rtems/termiostypes.h, include/sys/ioccom.h:
Update of PPPD to 2.3.11 from 2.3.5 touched these files.
* include/rtems/libio_.h: Added login name, uid, gid, euid, and egid
so they can be part of the private environment.
* include/rtems/libio_.h, libc/chroot.c, libc/privateenv.c:
Private environment and chroot() enhancements and fixes. Comments:
+ privateenv has been modified to let at chroot() to be more
POSIX like Sergei Organov recommended.
+ A task owner lets that rtems_set_private_env() will be
called twice or more times.
+ chroot() can be called without a previous
rtems_set_private_env(); (transpanrently)
+ The second call of rtems_set_private_env() makes a internal
chroot("/") into global imfs_root.
+ chroot() runs like chdir() without a previous chdir("/") with
the global root.
+ The current directory can be in a wrong place like Linux and
many other Unices.
* include/rtc.h: New file.
* include/Makefile.am: Updated to reflect above.
* sys/utsname.h: Added C++ wrapper.
* include/ioccom.h: Unreferenced and thus removed.
* include/zilog/Makefile.am, include/Makefile.am,
include/motorola/Makefile.am, include/sys/Makefile.am
include/rtems/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
* Alternate email is correo@fernando-ruiz.com
* libc/privateenv.c: New file.
* include/rtems/libio_.h, libc/Makefile.am, libc/base_fs.c,
libc/unmount.c: Moved default umask, current working directory,
root, and links followed count into a structure "user environment"
that can then be treated as a unit. This enable giving unique
copies of these to individual threads or collection of threads.
* include/rtems/Makefile.am: Added termiostypes.h.
* libc/Makefile.am: Removed termiostypes.h.
* libc/termios.c: Changed include of "termiostypes.h" to
<rtems/termiostypes.h> since that is an RTEMS specific header file.
* include/sys/ttycom.h: New file -- moved from libnetworking/sys.
* Makefile.am: Modified to reflect above.
* libc/termiostypes.h: New file -- missed in earlier commits.
libc/utime.c, libc/write.c:
<rtems/XXX.h>.
* libc/ioman.c: Moved to libfs.
* libc/Makefile.am: Removed ioman.c as part of moving it to libfs.
* libc/base_fs.c: Removed include of imfs.h and reworded comment
to avoid being IMFS specific.
* libc/libio.h: Removed prototype of IMFS_ops since it should
not be in this file.
* libc/mount.c: Removed IMFS specific configuration information.
* libc/unmount.c: Removed include of imfs.h and reworded comment
* libc/Makefile.am: Added mallocfreespace.c.
* libc/mallocfreespace.c: New file based on work by Nick Simon
<Nick.SIMON@syntegra.bt.co.uk> which he included in malloc.c.
* libc/libcsupport.h: Added prototype for malloc_free_space().
* libc/eval.c: Ditto.
* libc/fcntl.c: Ditto.
* libc/fsync.c: Ditto.
* libc/ioctl.c: Ditto.
* libc/ioman.c: Ditto.
* libc/link.c: Ditto.
* libc/memfile.c: Ditto.
* libc/mknod.c: Ditto.
* libc/symlink.c: Ditto.
Comments follow:
Building linux/posix fails due to including lib/include/sys/cdefs.h
instead of linux's sys/cdefs.h.
AFAIS, this sys/cdefs.h is specific to newlib and should probably
not be used on any unix host.
Therefore, I changed the relevant Makefile.am/configure.in to
condionally install sys/cdefs.h only if newlib is present.
This triggered another bug inside of the newlib-check for one of
RTEMS target's (Unfortunately I can't remember which - mips/i960 ?
... one of the more exotic ...), for which int func() isn't
identical to void func().
Note: This patch needs to be tested under Cygwin and Solaris. I am
particularily unsure about Cygwin/posix, as it applies a different
version newlib which must not trigger RTEMS newlib check (it is
supposed to fail) and if it may need RTEMS's sys/cdefs.h.
non-networking applications could include <sys/ioctl.h>.
configurations could see it while including <sys/ioctl.h> and
<sys/ioccom.h>.
of all FIO constants and conflict with libnetworking code.
significant things:
and PowerPC
same code base.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
initialization.
readdir support. The next step is to add a mount table and configure
either the miniIMFS or the full IMFS at the application level.
Renamed IMFS handler tables to include IMFS prefix.
places to make sure memory allocated for filesystem specifif nodes
gets freed.
to its own top level package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
