path: root/c/src/lib/include/sys (follow)
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-3/+3
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-8/+8
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-041-273/+0
* Regenerated.Joel Sherrill1999-10-041-5/+6
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-091-0/+272
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-0/+34
* Fix based on bug report from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-03-241-0/+25
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | There seems to be an ugly dependency between posix-headers and libcsupport. Configuring rtems with ../rtems-rc-19990324-0/configure \ --target=i386-rtems \ --prefix=<somewhere> \ --disable-posix "make RTEMS_BSP=pc386" results into: [...] /opt/rtems/bin/i386-rtems-gcc --pipe -B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems -I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall -ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c In file included from ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16: /opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or directory ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning: `struct utimbuf' declared inside parameter list ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning: its scope is only this definition or declaration, ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning: which is probably not what you want. ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function `utime': ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34: dereferencing pointer to incomplete type ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34: dereferencing pointer to incomplete type make[4]: *** [o-pc386/utime.o] Error 1 make[3]: *** [all] Error 1 make[2]: *** [all] Error 1 make[1]: *** [all] Error 1 make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c' make: *** [all] Error 1 Apparently sys/utime.h is one of the posix headers and therefore gets not installed (I suppose this is correct). IMO, this probably indicates that sys/utime.h has to be moved to another include subdirectory and should not be part of the posix-package. [AFAIK, sys/*.h are system dependent headers, so why should it be a posix-header? - Hmm]
* Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1998-12-101-3/+2
| | | | all conflicts.
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-12-101-0/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | From: Eric Norum <eric@skatter.usask.ca> Date: Sat, 5 Dec 98 13:20:51 -0600 What do you think of this patch? It implements your `tap' suggestion in a way that adds support for all ethernet devices with no driver modifications. I also added a return value from the tap function. If the return value is zero, the packet will be passed up the chain as usual. If the return value is non-zero the mbuf holding the packet will be freed and the packet will be dropped. If you like it, please submit it to Joel. I guess there needs to be an addition to the network documentation describing the additional ioctl's -- and a big warning that the tap function is called from a context that holds the network semaphore. Here is Eric's patch. I've tested it a bit, and made a couple of trivial changes. This is certainly better than mine: it should work for all Ethernet drivers. ================================================== The only concern I have about this patch is that the tap function may want to fiddle with the mbuf, calling functions like m_pullup and the like. If those force the networking code to rearrange the mbuf structure, then the caller's call to m_freem may crash. I don't know if this is a realistic concern--I don't know enough about the mbuf layer.
* Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs alongJoel Sherrill1998-10-281-0/+2
| | | | with libchip.
* Base filesJoel Sherrill1998-08-193-0/+219
* Added tcdrain(), cfgetospeed(), cfsetospeed(), cfgetispeed(), and cfsetispeed().Joel Sherrill1998-05-221-1/+5
* Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd.Joel Sherrill1997-08-011-0/+184
| | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers.
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+1
* posix support initially addedJoel Sherrill1995-09-261-0/+48
