path: root/c/src/lib/include/sys/utime.h (unfollow)
1999-03-24 Fix based on bug report from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-0/+0
There seems to be an ugly dependency between posix-headers and libcsupport. Configuring rtems with ../rtems-rc-19990324-0/configure \ --target=i386-rtems \ --prefix=<somewhere> \ --disable-posix "make RTEMS_BSP=pc386" results into: [...] /opt/rtems/bin/i386-rtems-gcc --pipe -B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems -I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall -ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c In file included from ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16: /opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or directory ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning: `struct utimbuf' declared inside parameter list ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning: its scope is only this definition or declaration, ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning: which is probably not what you want. ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function `utime': ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34: dereferencing pointer to incomplete type ../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34: dereferencing pointer to incomplete type make[4]: *** [o-pc386/utime.o] Error 1 make[3]: *** [all] Error 1 make[2]: *** [all] Error 1 make[1]: *** [all] Error 1 make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c' make: *** [all] Error 1 Apparently sys/utime.h is one of the posix headers and therefore gets not installed (I suppose this is correct). IMO, this probably indicates that sys/utime.h has to be moved to another include subdirectory and should not be part of the posix-package. [AFAIK, sys/*.h are system dependent headers, so why should it be a posix-header? - Hmm]
1998-11-23New files added as part of file system infrastructure effort.Joel Sherrill1-0/+25
