<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
all conflicts.
PROBLEMS
can/will be fixed.
1. Finally fixes raw interrupts for pc386
2. Makes some minor cleanup in console and startup
3. Makes rtems_termios_dequeue_characters() to return count of
outstanding chars - it allows to simplify console isrs a little
bit.
4. pc386 uart modified to be friendlier to termios parameter changes,
to have minor performance improvement and to take advantage of
of above termios modification.
Eric Norum per request from Geoffroy Montel:
> The rtems_termios_enqueue_raw_characters function type is void.
> The problem is that I can't return an error message if the input
> buffer is full.
> Could we add a return value?
Sure, but what would you do with the overflow indication? POSIX says,
``when the input limit is reached, the saved characters are thrown away
without notice''.
Anyhow, the change is so small I've done it and enclosed the patch.
support for device driver support on tcsetattr(), and hardware
flow control callbacks.
a result of enabling the newlib POSIX directory.
properly reflect the const on the buffer pointer being passed in.
Added new entry point to add in per physical port resource requirements.
(Sapporo, Japan) submitted the extended console driver for the
MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines.
This device driver supports four serial ports, cooked IO, and
provides a portable base for Zilog 8530 based console drivers.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
should simplify the build process.
+ variable length messages
+ named devices
+ debug monitor
newlib C library.
