2001-10-16 | 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -21/+0 | |
* include/zilog/Makefile.am: Remove. * include/motorola/Makefile.am: Remove. * include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5 * Makefile.am: Require automake-1.5. | |||||
2001-09-28 | 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='. * include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='. * include/sys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. | |||||
2001-02-05 | 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -3/+3 | |
* include/zilog/Makefile.am, include/Makefile.am, include/motorola/Makefile.am, include/sys/Makefile.am include/rtems/Makefile.am: Apply include_*HEADERS instead of H_FILES. | |||||
2000-11-30 | 2000-11-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* include/rtems/Makefile.am: Added termiostypes.h. * libc/Makefile.am: Removed termiostypes.h. * libc/termios.c: Changed include of "termiostypes.h" to <rtems/termiostypes.h> since that is an RTEMS specific header file. | |||||
2000-11-01 | 2000-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -4/+1 | |
* include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files. | |||||
2000-08-30 | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -6/+3 | |
1999-11-22 | Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -6/+6 | |
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams. | |||||
1999-10-04 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1 | -3/+3 | |
where wrapup left pieces out of the librtemsall.a. | |||||
1999-09-07 | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 1 | -0/+27 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. |
