path: root/c/src/lib/include/motorola (follow)
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-3/+3
| | | | | | | * include/zilog/Makefile.am, include/Makefile.am, include/motorola/Makefile.am, include/sys/Makefile.am include/rtems/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-6/+3
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-041-269/+0
* Regenerated.Joel Sherrill1999-10-041-5/+6
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-091-0/+268
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-0/+24
* Corrected spelling error.Joel Sherrill1998-09-111-10/+10
* new implementation of mc68681.hJoel Sherrill1997-08-041-72/+291
* moved from main include directoryJoel Sherrill1997-08-042-0/+158
