* include/sys/utsname.h: Added, removed times (now in newlib).
* Makefile.am: Merge include/Makefile.am
* libc/utsname.c: Relocated from posix/src.
* libc/Makefile.am: Reflect changes above.
* configure.ac: Remove include/Makefile
* sys/ioctl.h: Remove.
* sys/sockio.h: Remove.
* sys/filio.h: Remove.
* sys/Makefile.am: Reflect changes above.
* configure.ac: Take out *NETWORKING*.
* include/Makefile.am: Add stdint.h and inttypes.h.
(reported by Mike Siers <mikes@poliac.com>)
* include/stdint.h: New file.
* include/inttypes.h: New file.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/printk.c: Include rtems/bspIo.h instead of bspIo.h.
* include/Makefile.am: Remove bspIo.h.
* include/bspIo.h: Removed.
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs, require automake-1.5
* include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtc.h: New file.
* include/Makefile.am: Updated to reflect above.
* include/zilog/Makefile.am, include/Makefile.am,
include/motorola/Makefile.am, include/sys/Makefile.am
include/rtems/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
libc/utime.c, libc/write.c:
<rtems/XXX.h>.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
to its own top level package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
