path: root/c/src/lib/ChangeLog (unfollow)
2002-10-212002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+6
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
2002-05-172001-05-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+6
* libc/envlock.c: Implemented code to let newlib's envlock share the libio open/close mutex. Since both should be lightly used, this should not lead to problems and saves resources.
2002-05-152002-05-15 Chris Johns <ccj@acm.org>Joel Sherrill1-0/+8
* libc/newlibc.c: Per PR141, move the C library re-enterrant support directly into the thread dispatch code. RTEMS needs libc and so requiring libc to use a user extension with its overhead is not the best solution. This patch lowers the overhead to 2 pointer moves.
2002-05-152001-05-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+5
* libc/Makefile.am: envlock.c should only be built for embedded targets using newlib.
2002-05-142001-05-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill1-0/+7
* Per PR212, added envlock support for newlib. This is used by at least getenv()/putenv() to avoid race conditions. * libc/envlock.c: New file. * libc/Makefile.am: Modified to reflect above.
2002-05-142002-05-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+11
* include/Makefile.am: Remove. * include/sys/utsname.h: Added, removed times (now in newlib). * Makefile.am: Merge include/Makefile.am * libc/utsname.c: Relocated from posix/src. * libc/Makefile.am: Reflect changes above. * configure.ac: Remove include/Makefile
2002-05-142002-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+8
* include/sys/ioctl.h: Relocated from libnetworking/sys. * include/sys/filio.h: Relocated from libnetworking/sys. * include/sys/sockio.h: Relocated from libnetworking/sys. * include/Makefile.am: Reflect changes above. * configure.ac: Take out *NETWORKING*.
2002-04-262001-04-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+5
* libc/gxx_wrappers.c: Fix to keep prototype same as in gcc and remove warning.
2002-04-172002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* libc/scandir.c: Initialize nitems = 0.
2002-04-162002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* include/Makefile.am: Add stdint.h and inttypes.h. (reported by Mike Siers <mikes@poliac.com>) * include/stdint.h: New file. * include/inttypes.h: New file.
2002-04-082002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* libc/stat.c: include <string.h>. * libc/printk.c: Remove libcpu/cpu.h.
2002-04-032002-04-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* libc/ctermid.c: Include <string.h>. * libc/ttyname.c: Ditto. * libc/ttyname_r.c: Ditto.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+9
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-202001-03-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+6
* PR143 * lib/include/rtems/termiostypes.h: Removed unneeded volatile on "theBuf" since no byte is read more than once anyway.
2002-03-012002-03-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill1-0/+6
* libc/gxx_wrappers.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex.
2002-01-312001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill1-0/+11
* Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * libc/termios.c: Added PPCDISC.
2002-01-162002-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* include/rtems/libio.h: Add #include <rtems/fs.h>. Reflect changes due to using rtems/fs.h. * include/rtems/libio_.h: Reworked.
2002-01-082002-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* libc/gxx_wrappers.c: Add #include <rtems/error.h>.
2002-01-062002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* libc/Makefile.am: Add MULTISUBDIR support. * libc/fcntl.c: Add #include <stdarg.h>. * libc/privateenv.c: Add #include <stdlib.h>.
2002-01-042002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+72
* include/rtems/libio_.h: Remove set_errno_and_return_minus_one. * libc/cfsetispeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/cfsetospeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chown.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chroot.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/closedir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/eval.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fdatasync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fpathconf.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fstat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fsync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ftruncate.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/getdents.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ioctl.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/link.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/lseek.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/mknod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/open.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/read.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/readlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/rmdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/stat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/symlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/tcsetattr.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/telldir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname_r.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/utime.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/write.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one.
2002-01-042002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* libc/printk.c: Include rtems/bspIo.h instead of bspIo.h. * include/Makefile.am: Remove bspIo.h. * include/bspIo.h: Removed.
2001-11-302001-11-30 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill1-0/+5
This was tracked as PR88. * libc/scandir.c: Fixed to perform cleanup on error conditions.
2001-11-072001-11-07 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill1-0/+7
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63. * libc/chdir.c: Check for search/execute permissions on chdir. This requires passing RTEMS_LIBIO_PERMS_SEARCH to rtems_filesystem_evaluate_path().
2001-10-262001-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+5
* libc/libio.c: Cleanup of initialization per suggestion from Eric Norum.
2001-10-252001-10-25 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill1-0/+7
* libc/unmount.c: Primarily restructuring and clean up to address procedures which did not do what their name implied. Also addressed problem situation where unmount fails and the filesystem was inconsistent. The mounted filesystem could have been left hanging.
* libc/libio.c: Initialize more fields to NULL/0 during initialiation. * include/rtems/libio_.h: Fix freenode macro so it works for sockets which do not have the full set of filesystem operations and are initialized via something other than open().
2001-10-192001-10-18 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill1-0/+5
* libc/open.c, libc/close.c: Moved freenode from open to close.
2001-10-172001-10-17 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill1-0/+16
* These changes were discussed and reviewed by many people but the primary people were Jennifer Averett <jennifer@OARcorp.com> and Eugeny Mints <jack@oktet.ru>. * libc/utime.c: Add missing call to rtems_filesystem_freenode() at verification that utime is supported by the filesystem. * libc/link.c: Remove calls to freenode when the node was not successfully allocated. * libc/unmount.c: In the method file_systems_below_this_mountpoint() added calls to correctly free fs_root_loc when a failure occurs. * libc/open.c: Add freenode calls upon failure. * libc/open.c, lib/libc/close.c: (PENDING -- NOT INCLUDED THIS TIMER) Modifications the move the freenode from open() to close() (also part of this patch) are pending further discussion.
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+9
* include/zilog/Makefile.am: Remove. * include/motorola/Makefile.am: Remove. * include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5 * Makefile.am: Require automake-1.5.
2001-10-122001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* include/chain.h: Fixed typo.
2001-10-112001-10-11 Mike Siers <mikes@poliac.com>Joel Sherrill1-0/+9
* libc/termios.c: Fixed a memory leak in the termios software. Basically the tty open function was allocating an input raw buffer, an output raw buffer, and a cooked buffer that were not getting released. I have attached a patch for the latest snapshot. The patch also has a fix to ensure the tty link list is updated correctly when a tty is closed.
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
2001-10-102001-10-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+5
* libc/printk.c (printNum): Properly handle a maxwidth of 0 as reported by Nick Hennenfent <NICK.HENNENFENT@ROCHE.COM>.
2001-09-282001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+8
* include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='. * include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='. * include/sys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-242001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* include/sys/Makefile.am: Use = instead of += to setup NETWORKING_H_FILES and NEWLIB_H_FILES.
* libc/Makefile.am: Revamp INCLUDES handling to make automake-1.5 happy.
2001-09-212001-09-14 Eric Norum <eric.norum@usask.ca>Joel Sherrill1-0/+4
* libc/gxx_wrappers.c: Modifications to make gcc 3.x happy.
2001-08-172001-08-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+8
* include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX is defined on GNU/Linux (RedHat 6.2 distribution). * libc/unixlibc.c: Added stubs for rtems_io_register_name() and rtems_io_lookup_name() so UNIX port would compile the IO manager sptest that registers /dev/null.
2001-08-172001-08-10 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill1-0/+15
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector number range check and handling of interrupt priority regs to conform SH2 specs. * sci/sci_termios.c: New file. * include/sci_termios.h: New file. * include/Makefile.am (EXTRA_DIST): Added sci_termios.h. (include_sh_HEADERS): Added sci_termios.h. * score/ispsh7045.c (isp): Calling an ISR with immediate argument casued negative sign extension for vector numbers of 128 and above. This was fixed. * sci/sci.c: Cleaned initialization of SCI registers; added necessary setup for new TERMIOS console cooperation
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+8
* libc/lseek.c: Modified after discussion with Eugeny S. Mints <jack@oktet.ru> to correct the behavior. There were two mistakes. First, iop->offset was incorrectly set for SEEK_END. Second, iop->offset should be left unmodified if there are errors. This modification attempts to fix both situations.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill1-0/+5
* include/rtems/termiostypes.h, include/sys/ioccom.h: Update of PPPD to 2.3.11 from 2.3.5 touched these files.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill1-0/+15
* libc/termios.c: Fix a bug in the termios implementation in the following scenario: The General Terminal Interface document that me states that if VMIN = 0 and VTIME = 0, then read() should return the minimum of two values: a) number of bytes available b) number of bytes requested (I assume from the read call) The current implementation of the fillBufferQueue() in termios.c is always return 1 character with these setting values. I know the termios buffer has more than one character available and my read() call is requesting 1024 bytes.
2001-08-092001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill1-0/+5
* libc/getgrent.c, libc/getpwent.c: the 'ls' and more related command previous failed after a chroot(). (unknown user & group)
2001-08-032001-08-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+6
* libc/libio_sockets.c (rtems_bsdnet_fdToSocket): Per bug report from Gene Smith <Gene.Smith@sea.siemens.com>, enhanced the error checking to account for a socket being closed.
2001-05-252001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+6
* libc/base_fs.c: Deleted chmod() now that IMFS creates the root node with the desired permissions. chmod() is also not supported by the miniIMFS so this is not allowable.
2001-05-242000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill1-0/+5
* include/rtems/libio_.h: Added login name, uid, gid, euid, and egid so they can be part of the private environment.
2001-05-242000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill1-0/+7
* libc/ttyname.c (ttyname_r): Removed duplicate call to closedir(). * libc/getpwent.c: Create a more robust /etc/passwd and /etc/group. * libc/base_fs.c: Change permissions of files and directories. Now uses octal constants.
2001-05-112001-05-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+5
* libc/write.c: Change type of rc to match return type from underlying function per report from Eric Norum.
2001-05-072001-04-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
2001-04-242001-04-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+9
* libc/libio.c (rtems_libio_allocate): Make sure size and offset fields are cleared on each file open. Before this field was cleared, this resulted in the value from the last time that IOP was used being still in place. Discovered by Andrew Bythell <abythell@nortelnetworks.com>. * libc/open.c: Remove redundant setting of iop->offset.
