* | 2000-10-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-18 | 1 | -1/+9 | |
| | | | | | | | * libc/fcntl.c: Do not require every filesystem to have an fcntl() handler. Most fcntl() operations can be performed with no filesystem support. * ChangeLog: Corrected comment. | |||||
* | 2000-09-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-28 | 1 | -0/+15 | |
| | | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change. | |||||
* | 2000-09-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-22 | 1 | -0/+4 | |
| | | | | * libc/newlibc.c: Removed _A29K specific ifdef. | |||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-06 | 1 | -0/+4 | |
| | | | | * configure.in: Cleanup comments. | |||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -0/+4 | |
| | | | | * libc/Makefile.am: Include compile.am | |||||
* | 2000-09-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-05 | 1 | -0/+4 | |
| | | | | * libio.c: Added O_NONBLOCK to list of flags. | |||||
* | 2000-08-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-08-30 | 1 | -0/+5 | |
| | | | | | * configure.in: Remove libcpu and libbsp * Makefile.am: Remove libcpu and libbsp | |||||
* | 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2000-08-25 | 1 | -0/+4 | |
| | | | | * libc/fs_null_handlers.c: Added missing rmnod entry. | |||||
* | 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2000-08-25 | 1 | -0/+5 | |
| | | | | | * libc/isatty.c, libc/imfs_handlers_directory.c, libc/creat.c, libc/imfs_directory.c: Fixed style issues. | |||||
* | 2000-08-11 Chris Johns <ccj@acm.org> | Joel Sherrill | 2000-08-11 | 1 | -0/+15 | |
| | | | | | | | | | | | | | | | * libc/chmod.c: Return ENOTSUP if filesystem does not have handler. * libc/eval.c: Ditto. * libc/fcntl.c: Ditto. * libc/fsync.c: Ditto. * libc/ioctl.c: Ditto. * libc/ioman.c: Ditto. * libc/link.c: Ditto. * libc/memfile.c: Ditto. * libc/mknod.c: Ditto. * libc/symlink.c: Ditto. * libc/libio.h(rtems_filesystem_dev_major_t): New macro. * libc/libio.h(rtems_filesystem_dev_minor_t): New macro. | |||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+4 | |
