* | Comment added. | Jennifer Averett | 1999-11-17 | 1 | -1/+2 |
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 618 | -1230/+620 |
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 99 | -2/+295 |
* | Updated Mailbox Manager submitted and split into multiple files. | Joel Sherrill | 1999-11-17 | 11 | -344/+470 |
* | Update from Andrew D. McDowell <amcdowel@cs.uah.edu> with modifications | Joel Sherrill | 1999-11-17 | 1 | -7/+257 |
| | | | | | by Joel and Jennifer based on experience merging the other managers and cleaning them up. No test code is available at this point. | ||||
* | Moved task_variable pointer to basic shared part of TCB instead of | Joel Sherrill | 1999-11-16 | 5 | -38/+26 |
| | | | | | | | RTEMS API extension to avoid problems when the extension is freed. Eventually the task variable switch extension should become part of the core context switch and the Ada tcb self implemented in terms of it. | ||||
* | Added check to return passed if task is not suspended. | Jennifer Averett | 1999-11-16 | 2 | -1/+7 |
* | Added code to catch the error of suspend count exceding the counter value. | Jennifer Averett | 1999-11-16 | 1 | -0/+4 |
* | Fixed bug. | Jennifer Averett | 1999-11-16 | 1 | -3/+3 |
* | Added handler for fsync. For the memfile it is the same as the data sync. | Jennifer Averett | 1999-11-16 | 1 | -1/+1 |
* | Web server uses the POSIX API. Therefor, it must be disabled when the | Joel Sherrill | 1999-11-16 | 1 | -1/+5 |
| | | | | POSIX API is disabled. | ||||
* | Removed start subdirectory and distributed contents to the appropriate | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
| | | | | places under the libbsp tree. | ||||
* | Added comments. | Joel Sherrill | 1999-11-16 | 3 | -3/+10 |
* | Now use _Thread_Reset(). | Joel Sherrill | 1999-11-16 | 1 | -19/+4 |
* | Added threadreset.c. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added prototype for _Thread_Reset() and numerous comments. | Joel Sherrill | 1999-11-16 | 1 | -4/+28 |
* | Only check for System V IPC if multiprocessing is enabled. The unix | Joel Sherrill | 1999-11-16 | 3 | -2/+15 |
| | | | | | | | | port only uses System V IPC for shared memory and semaphores to communicate between nodes in a multiprocessor configuration. If you disable multiprocessing, then this code should be unused. Thus systems like Cygwin which are POSIX but do not support System V IPC should not work. | ||||
* | Fixed so can be included multiple times in the executive source. | Joel Sherrill | 1999-11-16 | 1 | -0/+9 |
* | Works now. | Joel Sherrill | 1999-11-16 | 2 | -38/+24 |
| | | | | | Removed times() since the version in the C Library support code is fine. | ||||
* | Return a reasonable error other than ENOSYS. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added call to _Watchdog_Remove to remove the sporadic timer. It was | Joel Sherrill | 1999-11-16 | 1 | -0/+1 |
| | | | | being reinserted onto the ticks chain. | ||||
* | Moved utsname from "build for now" (unimplemented files) to the main | Joel Sherrill | 1999-11-16 | 1 | -4/+5 |
| | | | | list of C_PIECES since it is now implemented. | ||||
* | Comment fixed when adding prototype for | Joel Sherrill | 1999-11-16 | 1 | -2/+11 |
| | | | | _ITRON_Message_buffer_Translate_core_message_buffer_return_code. | ||||
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+66 |
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+113 |
* | Added. | Joel Sherrill | 1999-11-16 | 5 | -0/+205 |
* | Source and destination arguments to strncpy were swapped. This mistake | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
| | | | | was made in the conversion of bcopy() to strncpy(). | ||||
* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 1 | -21/+0 |
* | Returned third parameter for a NULL name to the objects open call. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 11 | -81/+97 |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | ||||
* | + Modified to use new Thread_Reset routine instead of the restart method. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 12 | -355/+524 |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 9 | -285/+378 |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -37/+27 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 1 | -11/+11 |
| | | | | + Removed error path that should never happen. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -17/+8 |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 1 | -5/+5 |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 1 | -0/+7 |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 1 | -13/+12 |
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -15/+10 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -5/+2 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | Corrected so now actually indexes into the allocation block. | Joel Sherrill | 1999-11-12 | 1 | -10/+6 |
* | Corrected remaining references to struct rtems_task_variable_t since | Joel Sherrill | 1999-11-12 | 2 | -7/+11 |
| | | | | it is now typedef'ed. | ||||
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1999-11-12 | 1 | -0/+13 |
* | Used typedef so all "struct rtems_task_variable_t" uses are now | Joel Sherrill | 1999-11-12 | 4 | -19/+19 |
| | | | | just "rtems_task_variable_t". | ||||
* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 1 | -4/+36 |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | ||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 4 | -4/+224 |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | ||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 1 | -243/+239 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 |
