of theses targets...
Here is a pure sh-rtems bug-fix patch.
The defines to enable the network to host conversion macros in
netinet/in.h were missing in sh/cpu.h
returned a buffer which was not zero-filled, the reference count
was not correct. When the application exitted, the "lastClose"
handler was not being called to flush the output. This problem
had manifested itself on a variety of platforms.
The function rtems_termios_dequeue_characters() incorrectly incremented
the buffer pointers when it was invoked and there were no characters
in the ring buffer. This problem had also manifested itself on a
variety of platforms. The symptom was a strange repeating of the
data in the transmitter buffer when the transmitter serial device
was supposed to go idle.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
* c/src/exec/score/tools/sh - NEW DIRECTORY - contains shgen
Most of it should be self-explanatory. I am a little bit concerned about
host-dependent features (getopt, floating point libraries). This
shouldn't disturb much now, as this tool should be compileable on all
gnu-based hosts and is only applicable for the sh. But in case somebody
complains, we may need to add autoconf checks or even restructurize
parts of rtems (IMO, rtems needs to be restructurized - remember the
"turning rtems upside down" issue).
Haven't had a chance to do an extensive shake-out of 980710, but it
builds just fine on FreeBSD 2.2.5 (after termios is fixed using the
attached patch), and the tests run fine. FYI: FreeBSD doesn't support
System V IPC out of the box, but one only needs to add three options
to the kernel build configuration file, recompile the kernel, and
you're ready.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
between CPU32 and CPU32+ cores. Commentary follows:
Unfortunately c/src/exec/score/cpu/m68k/m68k.h incorrectly defines
M68K_HAS_MISALIGNED for the plain old CPU32 (it is correct for the CPU32+).
As a consequence, the recently-relocated m68k memcpy() may still attempt
misaligned memory accesses.
I suggest that until such time as egcs/gcc differentiates these cores
that we invent a new preprocessor symbol, RTEMS__mcpu32p__ for this
purpose, on the assumption that egcs may one day grow a -mcpu32+ option
which will define a __mcpu32p__ symbol (whether this option would also
define __mcpu32__ is yet to be resolved).
BSPs that have a CPU32+ (like gen68360) would for the time being define
RTEMS__mcpu32p__ using -D. The symbol is `RTEMS__mcpu32p__' because
symbols of the form __xxx__ should only be defined by the compiler
itself.
Note that the patch tests for RTEMS__mcpu32p__ *before* __mcpu32__, since
__mcpu32__ is still defined for the CPU32+. It does not change the
gen68360 BSP.
An aside:
Note that in egcs-1.0.3a, the option -m68332 is identical to -mcpu32,
except it defines __mc68332__ as well as __mcpu32__. This is only
for the sake of compatibility. The story with -m68302 is similar;
it defines __mc68302__ and __mc68000__. In my opinion these options
are depreciated and ought to be avoided in RTEMS.
clarity.
task to be deleted was created via the same API (i.e. were of the object
class created by this API). For example, a POSIX thread calling
the rtems_task_delete(SELF) directive would incorrectly update the RTEMS
object local pointer table.
Jennifer discovered this when moving tests implemented in C using the
Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly
using POSIX services. This lead to some unexpected behavior.
not a valid object class. This was discovered while looking for
a bug reported by Jennifer.
of seconds since 1988 from RTEMS and not adding in the 1970-1988 correction
factor. Plus removed checks for data/time set since POSIX does not permit
this call to fail. GNAT 3.12 depends on this.
important distinctions between CPU models which are not made by gcc.
These distinctions help give us a more optimized memcpy(). This is important
for message queues and KA9Q.
vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
external interrupt priorities were not being honored. Here is some
of his original report:
using rtems/erc32, I have a problem with interrupt priority when
interrupts occure simultaneously. Erc32 has an interrupt force
register where interrupts can be generated. If more than one
interrupt is generated, the interrupt handlers are scheduled in
the wrong order, i.e. with the lowest priority first.
I have attched a program that generates three interrupts, 0x11, 0x12
and 0x13. Interrupt 0x13 should be handled first, but is actually
handled last. Below is the output from sis:
sis> go
resuming at 0x02000000
RAM size: 4096 K, ROM size: 2048 K
Watchdog disabled
Waitstates = RAM read: 0, RAM write: 0, ROM read: 0, ROM write: 0
Power-down mode enabled
infinite UART baudrate
External interrupt received with vector 0x11
External interrupt received with vector 0x12
External interrupt received with vector 0x13
I have verified that sis generates the interrupts in the correct
order, i.e. 0x13 first, then 0x12 and then 0x11. So the problem
seems to be in the rtems interrupt handler. Do you use the PIL field
in the %psr register to mask lower priority interrupts or are all
external interrupts considered to have the same priority ..?
Here is a description of the fix:
it turned out that lower priority interrupts were not at all masked
off during interrupt handling. I made the following fix to cpu_asm.s:
... fix is in the code ...
There might be a simpler way of doing this, but this works...
cfsetispeed().
or solaris2.
Eric Norum per request from Geoffroy Montel:
> The rtems_termios_enqueue_raw_characters function type is void.
> The problem is that I can't return an error message if the input
> buffer is full.
> Could we add a return value?
Sure, but what would you do with the overflow indication? POSIX says,
``when the input limit is reached, the saved characters are thrown away
without notice''.
Anyhow, the change is so small I've done it and enclosed the patch.
support for device driver support on tcsetattr(), and hardware
flow control callbacks.
used to calculate the amount of memory used by tasks whether the
POSIX API is enabled or disabled.
advantage of this instruction.
Also up conditionals mapping cpu models to feature flags by having a
section which defaults all the i386 family feature flags to the most
common value.
Actual patch was from Eric Norum.
