allows one to trace the enqueueing and dequeueing of messages. This
can be used to insure that packets are getting to the boundary between
the network stack and the device driver.
Added volatile to i386 assembly statements in header checksum code.
printing messages.
object code that has to be loaded just for initializing the signal
manager.
NULL pointer.
rtems_bsdnet_makeFdForSocket().
and eliminate a link error.
so that the libc code did not have to know about (struct socket).
split into multiple files.
outside RTEMS. Comment:
I found a couple of places other than RTEMS where I'd like to use
the declarations supplied in m68360.h. To make this easier to do,
I've redone the declarations in m68360.h to use standard C types.
<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
with the --disable-posix option, stubs for some routines (_getpid_r and
_kill_r) that are normally defined with POSIX were added.
getting the spurious trap handling to work required a couple more
fixes - I have attached a patch against rtems-4.0.0 with the
necessary changes. I also added functionality so that the
address of the trapped instruction is reported and in case of
a data access error, the data address is also reported.
> > I think I have found a bug in src/exec/scor/sparc/cpu/erc32.h in:
> > #define ERC32_Disable_interrupt( _source, _previous ) \
> > do { \
> > unsigned32 _level; \
> > unsigned32 _mask = 1 << (_source); \
> > sparc_disable_interrupts( _level ); \
> > (_previous) = ERC32_MEC.Interrupt_Mask; \
> > ERC32_MEC.Interrupt_Mask = _previous | _mask; \
> > sparc_enable_interrupts( _level ); \
> > (_previous) &= ~_mask; \ <- IS THIS CORRECT...?
> > } while (0)
> > The previous interrupt mask is returned after first clearing the
> > bit to be disabled, regardless whether the bit was set before or
> > not. If the bit was set (interrupt masked), subsequent call to
> > ERC32_Restore_interrupt() will enable the interrupt even though
> > it was supposed to be masked. This is indeed what happens in
> > DEBUG_puts when polled console I/O is used. In my opinion, the
> > last statement in the macro should be removed - what is your opinion?
> I think the "~" shouldn't be there. I recall that the intent of that line
> is to only return the state of the interrupts you were concerned with.
> Removing the line returns entire state. Given that the value returned
> shuold only be used in conjunction with the map, I suppose either removing
> the ~ or the entire line is correct? I can go either way. Just let me
> know which you think is more correct and the source will change. :)
Hmmm, just removing the '~' should be OK. DEBUG_puts() seems to be the
only user of ERC32_Restore_interrupt() anyway ...
prototype.
properly in conditionals
automake:
* I didn't yet touch the cpu subdirectory. I still need some time to
think on how to handle them.
* I probably will wait for the next snapshot before mailing more patches
(I still have some pending), giving you a chance to apply them and me a
chance to become target of the bullets which will probably be aimed at
me after these modifications.
<corsepiu@faw.uni-ulm.de>.
Some Makefile.ins depend on gcc by hard-coded gcc-specific compiler
flags:
-g added to CFLAGS /LDFLAGS in
> find . -name Makefile.in -exec grep -l ' \-g' {} \;
./c/src/lib/libbsp/i386/i386ex/startup/Makefile.in
./c/src/lib/libbsp/i386/pc386/tools/Makefile.in
-Wall added CFLAGS in
> find . -name Makefile.in -exec grep -l ' \-Wall' {} \;
./c/src/exec/score/tools/sh/Makefile.in
Both -g and -Wall should not be used in any Makefile.in (Yes, I know,
tools/sh/Makefile.in was written by me :-).
I'd like to propose to remove these flags from the files mentioned
above.
directory in preparation for automake:
Here is a shell script which reorganizes some parts of the exec/posix
source tree.
This shell scripts moves include files below exec/posix to different
locations than now. It doesn't yet apply automake, but still use the old
autoconf configuration scheme. It doesn't influence the build scheme at
all (unless I corrupted something), only the location of the header
files is different, which would ease applying automake later.
The purpose of this shell script is to demonstrate the style of
structural changes I would like to see in rtems in near future to
prepare a smooth transition to automake. Then CC could pickup rtems'
header files from their location inside of the source tree in future,
instead of the build tree as it is done now.
In case you would accept this patch/script, there would be more similiar
ones to come.
