* asm.h: Include cpuopts.h instead of targopts.h.
* rtems/new-exceptions/cpu.h: Relocated from
libbsp/powerpc/support/new_exception_processing/rtems/score/cpu.h
* rtems/old-exceptions/cpu.h: Relocated from
c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems/score/cpu.h
* rtems/powerpc/registers.h: Relocated and renamed from
libcpu/powerpc/shared/include/cpu.h.
* rtems/score/cpu.h: New.
* rtems/score/cpu.h (CPU_ISR_Disable and CPU_ISR_Enable): Correct them
where they correctly inform the compiler about the register they
are modifying.
* include/rtems/system.h: Remove targopts.h.
* libc/scandir.c: Initialize nitems = 0.
* include/rtems/system.h: Add the sparc to the target supporting
multlibs.
* src/threadinitialize.c: Per PR181, clear the array of user extension
pointers. This lets user extensions that have hooked the switch handler
know if a task has been processed by the user extension before. If a
user extension is created after a task is started it may not know it.
* include/Makefile.am: Add stdint.h and inttypes.h.
(reported by Mike Siers <mikes@poliac.com>)
* include/stdint.h: New file.
* include/inttypes.h: New file.
* c/src/libnetworking/rtems/rtems_bsdnet.h: To address PR59, added
the drv_ctrl driver control block field to the ifconfig network driver
structure. This field is needed by the i82586 driver which was ported
from NetBSD as it had better hardware abstraction.
* include/rtems/system.h: Add i386 to multilib-able targets.
* rtems/score/idtr.h: New file, extracted from libcpu/cpu.h.
* rtems/score/interrupts.h: New file, extracted from libcpu/cpu.h.
* rtems/score/registers.h: New file, moved from libcpu.
* cpu.c: Don't include cpuModel.h,
#include <rtems.h>,
#include <rtems/score/i386types.h>,
#include <rtems/score/idtr.h>.
* rtems/score/cpu.h: Don't include libcpu/cpu.h.
#include <rtems/score/interrupts.h>,
#include <rtems/score/registers.h>.
* macros/rtems/score/userext.inl: Now works after merging patch for
functionality requested in PR174.
* inline/rtems/score/userext.inl: Added a comment explaining the
order in which routines appear since it is not the obvious order.
* Per PR141 and PR174, make task switch extension its own list and
fix all odd problems introduced by providing macro version.
* inline/rtems/score/userext.inl: Fix.
* libc/stat.c: include <string.h>.
* libc/printk.c: Remove libcpu/cpu.h.
* src/ramdisk.c: include <string.h>.
* src/blkdev.c: include <string.h>.
* src/imfs/imfs_getchild.c: include <string.h>.
* src/imfs/imfs_gtkn.c: Include <string.h>.
* src/imfs/ioman.c: Include <string.h>.
* src/imfs/linearfile.c: Include <string.h>.
* src/imfs/memfile.c: Include <string.h>.
* include/rtems/bspIo.h: Fix cpp-guards, remove references to i386.
* rtems.c: Adaptation to gcc-3.0.x.
* src/psignal.c: Include <stdlib.h>.
* ChangeLog: Fix dates.
* src/tasks.c: Pre-initialized switch extension for list.
* macros/rtems/score/timer.inl: Corrected typo on end of line.
* macros/rtems/score/object.inl: Corrected arguments.
* macros/rtems/score/userext.inl: Updated to reflect modifications
to inline version from PR142.
* inline/rtems/score/userext.inl: Cleanup as side-effect of above.
* Per PR142, make task switch extension its own list.
* include/rtems/score/userext.h: Reflect above by adding
User_extensions_Switch_control and adding it to User_extenions_Control.
* inline/rtems/score/userext.inl: Allocate all memory in one chunk
to minimize overhead. Address processing dedicated switch chain.
* src/tasks.c (_RTEMS_tasks_User_extensions): Reflect above.
* src/pthread.c (_POSIX_Threads_User_extensions): Reflect above.
* src/dosfs/Makefile.am: Per PR129 do not install as many files
to the $(includedir).
* src/dosfs/fat.h: Include <string.h>.
Remove DBG1 and DBG2 (unused).
* Per PR169.
* src/dosfs/config.h.in, src/dosfs/stamp-h2.in: Removed from CVS.
* libc/ctermid.c: Include <string.h>.
* libc/ttyname.c: Ditto.
* libc/ttyname_r.c: Ditto.
* src/getegid.c: Remove <errno.h>.
* src/geteuid.c: Ditto.
* src/getgid.c: Ditto.
* src/getuid.c: Ditto.
* src/getlogin.c: Move <errno.h>.
* cpu.c: Remove call to sparc_init_tbr/NO_TABLE_MOVE.
* rtems/score/cpu.h: Remove NO_TABLE_MOVE conditional code.
* include/rtems/score/ispsh7750.h, score/ispsh7750.c: Account for
name change.
* rtems/score/cpu.h: Account for name change.
* rtems/score/unixtypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/score/sparctypes.h: Removed.
* rtems/score/shtypes.h: Removed.
* rtems/score/ppctypes.h: Removed.
* rtems/score/or32types.h: Removed.
* rtems/score/or16types.h: Removed.
* rtems/score/no_cputypes.h: Removed.
* rtems/score/mipstypes.h: Removed.
* rtems/score/m68ktypes.h: Removed.
* rtems/score/i960types.h: Removed.
* rtems/score/i386types.h: Removed.
* rtems/score/hppa1.1types.h: Removed.
* rtems/score/h8300types.h: Removed.
