* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 2 | -26/+90 |
| | | | | or rtems initialization table in configuration table | ||||
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 5 | -51/+52 |
| | | | | tasks table" | ||||
* | comment clean up | Joel Sherrill | 1996-05-29 | 16 | -32/+20 |
* | types.c: spacing | Joel Sherrill | 1996-05-29 | 2 | -28/+33 |
| | | | | | psignal.c: kill recognizes SIGABRT and exits to prevent asserts from recursively occurring because kill was not implemented and asserted. | ||||
* | fixed support for posix initialization threads table | Joel Sherrill | 1996-05-29 | 2 | -4/+44 |
* | added pthread_exit | Joel Sherrill | 1996-05-29 | 1 | -8/+45 |
| | | | | first posix thread ran | ||||
* | cleaned up spacing and parentheses | Joel Sherrill | 1996-05-29 | 2 | -4/+4 |
* | spacing | Joel Sherrill | 1996-05-29 | 1 | -0/+1 |
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 3 | -10/+78 |
* | addressed minimum stack size attribute. | Joel Sherrill | 1996-05-29 | 1 | -1/+4 |
| | | | | | | | There is a potential problem if setting PTHREAD_STACK_MIN to 0 does not work with all applications since it is in limit.h over in newlib. There is a potential build order issue with newlib needing to know the rtems cpu dependent stack size minimum. | ||||
* | *** empty log message *** | Joel Sherrill | 1996-05-29 | 1 | -0/+3 |
* | removed all ifdef's on NOT_IMPLEMENTED. | Joel Sherrill | 1996-05-29 | 10 | -44/+30 |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 2 | -4/+16 |
| | | | | threads table structure | ||||
* | Addressed RTEMS API initialization tasks table in a system without | Joel Sherrill | 1996-05-29 | 2 | -6/+14 |
| | | | | RTEMS initialization tasks. | ||||
* | Added default POSIX API configuration table. | Joel Sherrill | 1996-05-29 | 1 | -1/+13 |
* | It is now not an error to have 0 RTEMS initialization tasks since you could | Joel Sherrill | 1996-05-29 | 1 | -0/+6 |
| | | | | create POSIX initialization threads. | ||||
* | renamed signal.c to psignal.c to avoid naming problems. | Joel Sherrill | 1996-05-29 | 5 | -7/+119 |
| | | | | | | added mp stubs to cond.c and mutex.c to eliminate link errors. added pthread_exit to pthread.c | ||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 93 | -226/+372 |
| | | | | score, rtems api, or posix api related. | ||||
* | added maximum keys | Joel Sherrill | 1996-05-28 | 2 | -2/+2 |
* | added enumerated constant for the POSIX API as an error source | Joel Sherrill | 1996-05-28 | 2 | -2/+4 |
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 5 | -6/+166 |
* | new file | Joel Sherrill | 1996-05-28 | 1 | -0/+72 |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 2 | -0/+4 |
* | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 1996-05-28 | 2 | -2/+12 |
* | added posix api initialization call to init.c | Joel Sherrill | 1996-05-28 | 2 | -1/+5 |
| | | | | deleted a blank line in rtemsapi.c | ||||
* | comment cleanup | Joel Sherrill | 1996-05-28 | 2 | -4/+2 |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 2 | -0/+2 |
* | made posix configuration information conditional so configurations wanting | Joel Sherrill | 1996-05-28 | 4 | -2/+98 |
| | | | | only the rtems api don't have to include it. | ||||
* | changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
| | | | | | _ISR_Enable() takes the magic cookie expected by the cpu's status register instead of a simple isr level. | ||||
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 12 | -66/+281 |
* | changed version to 3.5.17 | Joel Sherrill | 1996-05-24 | 2 | -2/+2 |
* | updates to fix typos | Joel Sherrill | 1996-05-24 | 3 | -35/+35 |
* | updates from Tony Bennett | Joel Sherrill | 1996-05-23 | 6 | -98/+116 |
* | *** empty log message *** | Joel Sherrill | 1996-05-23 | 1 | -2/+2 |
* | invoke thread stack free routine instead of Workspace free. | Joel Sherrill | 1996-05-23 | 1 | -2/+26 |
* | updates from Tony Bennett. | Joel Sherrill | 1996-05-23 | 2 | -60/+78 |
| | | | | | Broke the setjmp/longjmp pair in the context switch into a separate routine so no code depended on local variables surviving the jump. | ||||
* | Modified to correct variables which defined the range of object classes | Joel Sherrill | 1996-05-22 | 2 | -2/+2 |
| | | | | which are tasks. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 16 | -7/+27 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 6 | -22/+58 |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. | ||||
* | fixed typo | Joel Sherrill | 1996-05-10 | 1 | -1/+1 |
* | *** empty log message *** | Joel Sherrill | 1996-05-08 | 1 | -1/+2 |
* | Updated version to 3.5.15. | Joel Sherrill | 1996-05-02 | 2 | -2/+2 |
* | Updates from Eric Norum to use the mcpu32 flags and fix comments. | Joel Sherrill | 1996-05-01 | 2 | -30/+17 |
* | changed version number to 3.5.14 | Joel Sherrill | 1996-04-24 | 2 | -2/+2 |
* | added comment regarding stack alignment issues to thread stack allocation | Joel Sherrill | 1996-04-24 | 1 | -0/+14 |
| | | | | routine. | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 5 | -18/+40 |
* | Updates from Tony Bennett. | Joel Sherrill | 1996-04-22 | 4 | -25/+34 |
* | thread.c: added support for optional user provided stack allocator | Joel Sherrill | 1996-04-22 | 2 | -8/+123 |
| | | | | wkspace.c: made initialization routine a regular subroutine | ||||
* | made initialization routine a regular subroutine | Joel Sherrill | 1996-04-22 | 4 | -176/+0 |
* | interr.h: added stack allocater error code | Joel Sherrill | 1996-04-22 | 4 | -2/+30 |
| | | | | wkspace.h: made initialization routine a regular subroutine |
