* include/rtems/score/apimutex.h (_API_Mutex_Lock): Added missing
_ISR_Disable.
* rtems/score/cpu_asm.h: Enhanced to include register offsets.
* Makefile.am: Install rtems/score/cpu_asm.h.
* cpu.c: Significantly enhanced including the implementation of
_CPU_ISR_Get_level.
* cpu_asm.S: Improved behavior of context switch and interrupt
dispatching.
* rtems/score/arm.h: Improved the CPU model name determination.
* rtems/score/cpu.h: Improved interrupt disable/enable functions.
* netinet/in.h, netinet/ip.h, netinet/ip_var.h, netinet/tcp.h:
Modified to added packed attribute.o
* cpu_asm.S: Added SR_IEO to context restore to fix isr disabled
deadlock caused by interrupt arriving while dispatching.
* macros/rtems/score/object.inl: Corrected typos in
_Objects_Open, _Objects_Close, and _Objects_Namespace_remove.
* macros/rtems/score/object.inl: Corrected implementation of
to be consistent with the inline implementation.
* src/dpmemident.c, src/msgqident.c, src/partident.c,
src/ratemonident.c, src/regionident.c, src/semident.c,
src/timerident.c: Corrected use of name parameter to
be consistent with fixes implemented to string name processing
which were committed with the POSIX Message Queue update.
* include/rtems/posix/cancel.h, src/cancel.c, src/cancelrun.c,
src/mqueue.c, src/pthread.c, src/semaphore.c, src/setcancelstate.c,
src/setcanceltype.c, src/testcancel.c: Per PR164, corrected the
behavior of thread cancellation and did some cleanup as a side-effect.
* cpu.c, irq.c, rtems/score/cpu.h: Filled in something that was
marked XXX.
* rtems/score/cpu.h: Filled in something that was marked XXX.
* automake/multilib.am: Add install-multi.
* aclocal/rtems-top.m4: Reflect new RTEMS_TOPdir to detecting
version.m4.
Add --with-project-root.
Reflect --with-project-root to setting up PROJECT_ROOT.
* aclocal/env-rtemscpu.m4: Reflect new RTEMS_TOPdir (HACK).
* aclocal/check-cpu.m4: Reflect new RTEMS_TOPdir.
* aclocal/check-bsps.m4: Reflect new RTEMS_TOPdir.
* configure.ac: RTEMS_TOP(..).
* configure.ac: RTEMS_TOP(../..).
* Jump table for single entry point removed.
* include/rtems/directives.h, src/entrytable.c: Removed.
* include/Makefile.am, src/Makefile.am, src/exinit.c: Modified to
reflect above.
* Makefile.am: Remove reference to deprecated rtems.c.
* rtems.c: Remove.
* rtems.c: Remove.
* rtems.S: Remove.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* src/bdbuf.c: Modified as part of above.
* src/cre_mbf.c, src/cre_sem.c, src/eventflags.c, src/fmempool.c,
src/itronsem.c, src/mbox.c, src/msgbuffer.c, src/port.c, src/task.c,
src/vmempool.c: Modified as part of above.
* src/__times.c: Corrected from previous attempt to cleanup.
* include/rtems/posix/key.h, src/cond.c, src/condinit.c, src/intr.c,
src/key.c, src/keycreate.c, src/keydelete.c, src/killinfo.c,
src/mqueue.c, src/mqueuecreatesupp.c, src/mutex.c, src/mutexinit.c,
src/psignal.c, src/pthread.c, src/semaphore.c,
src/semaphorecreatesupp.c: Modified as part of above.
* include/rtems.h, inline/rtems/rtems/region.inl,
macros/rtems/rtems/region.inl, src/dpmem.c, src/dpmemcreate.c,
src/msg.c, src/msgqcreate.c, src/part.c, src/partcreate.c,
src/ratemon.c, src/ratemoncreate.c, src/region.c, src/regioncreate.c,
src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c,
src/regiongetsegment.c, src/regiongetsegmentsize.c,
src/regionident.c, src/regionreturnsegment.c, src/rtemstimer.c,
src/sem.c, src/semcreate.c, src/taskcreate.c, src/taskident.c,
src/tasks.c, src/timercreate.c: Modified as part of above.
* include/confdefs.h, src/exinit.c, src/extension.c, src/itronapi.c,
src/posixapi.c, src/rtemsapi.c: Modified as part of above.
* include/Makefile.am, include/rtems/score/coremsg.h,
include/rtems/score/coremutex.h, include/rtems/score/coresem.h,
include/rtems/score/object.h, include/rtems/score/threadq.h,
inline/rtems/score/object.inl, inline/rtems/score/thread.inl,
macros/rtems/score/object.inl, src/Makefile.am, src/coremsg.c,
src/coremutex.c, src/coresem.c, src/mpci.c,
src/objectcomparenameraw.c, src/objectextendinformation.c,
src/objectinitializeinformation.c, src/objectnametoid.c,
src/thread.c, src/threadclose.c, src/threadget.c, src/threadq.c,
src/threadqextractwithproxy.c: Modified as part of above.
* include/rtems/score/apimutex.h, src/objectgetnoprotection.c: New
files.
* rtems/score/cpu.h: Fixed comments and renamed
CPU_SYSTEM_INITIALIZATION_THREAD_EXTRA_STACK to
CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK to be consistent with other code.
* wrapup/Makefile.am: Install by using cpulibdir, cpulib_DATA.
* aclocal/check-bsp-cache.m4: Remove RTEMS_BSP_FAMILY.
* aclocal/project-root.m4: Remove.
* aclocal/enable-multiprocessing.m4: enable_multiprocessing=no.
* aclocal/prog-cc.m4: Remove obsolete comments.
Comment out GCCSED.
* src/__times.c: Cleaned up comments, return more information,
and eliminated the fatal error on clock not set since it cannot
occur.
* Addition of a ftp client filesystem, comparable to the tftp one.
* lib/ftpfs.c, rtems/ftpfs.h: New files.
* lib/Makefile.am, rtems/Makefile.am: Modified to reflect above.
* Makefile.am, cpu.c, cpu_asm.S, rtems.S: Modified to make
this all compile again. It has been a while since we have
had a semi-working hppa1.1-rtems cross compiler. :)
* configure.ac: Add RTEMS_PROG_CCAS
* aclocal/prog-ccas.m4: New.
* aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP.
RTEMS_GCC_PRINT
* aclocal/check-multiprocessing.m4: Fix typo.
* automake/compile.am: Remove CXX support.
Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
RTEMS_GCC_PRINT
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* configure.ac: Use AC_CONFIG_AUX_DIR(..).
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* wrapup/Makefile.am: Don't preinstall libnetworking.a.
* wrapup/Makefile.am: Don't preinstall libfs.a.
* src/Makefile.am: Don't preinstall libblock.a.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libposix.a.
* src/Makefile.am: Add libitron.a.
* aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP.
Allow building w/ --enable-multiprocessing --enable-multilib.
Eliminate RTEMS_HAS_MULTIPROCESSING.
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
