* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 484 | -972/+972 |
* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 43 | -96/+96 |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | ||||
* | Fixed comment. | Joel Sherrill | 1997-10-06 | 2 | -2/+2 |
* | Make Post an atomic operation. | Joel Sherrill | 1997-10-06 | 4 | -4/+24 |
* | Added _Thread_Enable_dispatch to already_timedout path on Wait_support. | Joel Sherrill | 1997-10-06 | 1 | -2/+3 |
* | If the specified time period is less than a clock tick, then | Joel Sherrill | 1997-10-05 | 1 | -1/+4 |
| | | | | it is arbitrarily assumed to be 1 clock tick. | ||||
* | Uncommented gettimeofday_r to resolve missing symbol. | Joel Sherrill | 1997-09-21 | 1 | -2/+0 |
* | Bug fix from Eric Norum: | Joel Sherrill | 1997-09-19 | 1 | -1/+0 |
| | | | | | | | | | | | After weeks of trying to figure why my RTEMS/KASQ server crashes now and then I found a nasty bug I introduced in adding multiple-driver support to libio. The bug only affects `add-on' driver classes (like the networking code). Old-style file descriptors were not affected. The bug cleared 32 bytes of memory (unspecified location) whenever a `close' of a socket was performed! I was clearing an IOP I hadn't allocated -- and the pointer wasn't initiallized, either! | ||||
* | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1997-08-28 | 3 | -2/+5 |
* | Added error numbers and changed default error code from 0 to -1 for | Joel Sherrill | 1997-08-27 | 1 | -7/+9 |
| | | | | error number mapping. | ||||
* | Corrected bug per Katsutoshi Shibuya's report: | Joel Sherrill | 1997-08-22 | 1 | -2/+2 |
| | | | | | | | The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM. | ||||
* | Moved reentrant wrappers into their own file. | Joel Sherrill | 1997-08-22 | 1 | -4/+2 |
* | Fixed iop/memory leak bug reported by Dan Dickey. | Joel Sherrill | 1997-08-22 | 1 | -1/+6 |
* | Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. | Joel Sherrill | 1997-08-22 | 1 | -10/+15 |
* | Added commit about missing support for condition initializer. | Joel Sherrill | 1997-08-22 | 2 | -0/+2 |
* | new implementation of mc68681.h | Joel Sherrill | 1997-08-04 | 1 | -72/+291 |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 2 | -8/+38 |
* | moved from main include directory | Joel Sherrill | 1997-08-04 | 5 | -0/+478 |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 3 | -1/+102 |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | ||||
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 2 | -0/+191 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 1 | -2/+55 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 6 | -30/+139 |
* | Added comment to indicate what the commented out C_PIECES indicated. | Joel Sherrill | 1997-07-31 | 1 | -2/+3 |
* | fixed typo | Joel Sherrill | 1997-07-18 | 2 | -8/+8 |
* | Strip the trace bit from the SR register when dispatching a thread when | Joel Sherrill | 1997-07-10 | 1 | -3/+5 |
| | | | | | exiting from an ISR. This allows the trace bit to be set on a per task basis and tracing to be limited to that task. | ||||
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 2 | -0/+411 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 3 | -3/+3 |
| | | | | Ada interface where entry is a keyword. | ||||
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+4 |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+10 |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 2 | -6/+6 |
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 1 | -0/+4 |
* | Added support for context switching the data used by the gcc m68k | Joel Sherrill | 1997-05-28 | 6 | -3/+111 |
| | | | | | | software floating point emulation code. Code implemented by Karen Sara Looney <Karen.Looney@colorado.edu> with much email assistance from Joel. | ||||
* | changed version number to 4.1.0. | Joel Sherrill | 1997-05-27 | 2 | -2/+2 |
* | Corrected by adding check for NULL address passed into get_status | Joel Sherrill | 1997-04-25 | 1 | -0/+3 |
| | | | | directive. | ||||
* | Added to comment header block to include new status directive. | Joel Sherrill | 1997-04-25 | 2 | -0/+2 |
* | Patch from Chris John <cjohns@awa.com.au> to add use of a select statement | Joel Sherrill | 1997-04-22 | 5 | -3/+180 |
| | | | | | | in the unix port idle thread task. This should keep the entire application from blocking when any component does a blocking application. Also added TOD_MICROSECONDS_TO_TICKS. | ||||
* | promote TOD_MICROSECONDS_TO_TICKS through API as RTEMS_MICROSECONDS_PER_TICK. | Joel Sherrill | 1997-04-22 | 2 | -0/+4 |
* | multiprocessing fixed on linux by fixing cpu.c so correct form of | Joel Sherrill | 1997-04-22 | 1 | -3/+4 |
| | | | | semctl was being invoked. | ||||
* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 7 | -72/+22 |
* | File changed to reflect change in license and copyright. | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 476 | -2354/+2354 |
* | Added FPSP support for MC68040 | Joel Sherrill | 1997-04-16 | 3 | -5/+71 |
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 4 | -8/+20 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | added code to prevent attempts to clean up the library when rtems is | Joel Sherrill | 1997-04-09 | 1 | -0/+8 |
| | | | | down. | ||||
* | added support for tracking thread cpu usage. | Joel Sherrill | 1997-04-09 | 1 | -0/+2 |
* | enhanced printf statements | Joel Sherrill | 1997-04-09 | 1 | -4/+4 |
* | corrected spacing. | Joel Sherrill | 1997-04-09 | 2 | -16/+16 |
* | added SYSTEM_STATE_SHUTDOWN | Joel Sherrill | 1997-04-09 | 2 | -0/+2 |
* | enhanced rtems_shutdown_executive to insure that no attempt will | Joel Sherrill | 1997-04-09 | 1 | -1/+4 |
| | | | | be made to shut the system down when it is down. | ||||
* | added support for statistics on rate monotonic periods. | Joel Sherrill | 1997-04-09 | 3 | -15/+142 |
