* | + Added comments | Jennifer Averett | 2000-01-13 | 3 | -8/+46 |
* | + Added and yellow line tested _CORE_message_queue_Flush_waiting_threads | Jennifer Averett | 2000-01-13 | 3 | -1/+174 |
| | | | | | and _CORE_message_queue_Insert_message for posix message queues. + Yellow line tested new source | ||||
* | Added comment. | Jennifer Averett | 2000-01-13 | 1 | -0/+1 |
* | + Comment cleanup | Jennifer Averett | 2000-01-13 | 4 | -15/+12 |
* | Removed referance to rtems error. | Jennifer Averett | 2000-01-13 | 1 | -1/+2 |
| | | | | Added correct include file. | ||||
* | Added comment to indicate this path does not occur. | Jennifer Averett | 2000-01-13 | 1 | -1/+2 |
* | + Added code for waiting send | Jennifer Averett | 2000-01-12 | 1 | -4/+39 |
| | | | | + Yellow lined tested routine with Posix message queue test (01) | ||||
* | Debugged and yellow line tested routines. | Jennifer Averett | 2000-01-12 | 3 | -41/+71 |
* | + Modified return codes | Jennifer Averett | 2000-01-12 | 1 | -16/+27 |
| | | | | | + Added messsage size check + Debugged and yellowed out routine | ||||
* | + Added signal processing. | Jennifer Averett | 2000-01-12 | 1 | -1/+3 |
| | | | | + Yellow line tested source. | ||||
* | + Modified to correct return codes. | Jennifer Averett | 2000-01-12 | 1 | -2/+5 |
| | | | | | + Removed extra flag attribute from message queue structure. + Yellow-lined all posix message queue routines. | ||||
* | + Changed call from core flush to core close routine. This flushes waiting | Jennifer Averett | 2000-01-12 | 1 | -2/+4 |
| | | | | queues as well as the messages. | ||||
* | + Removed name validation code (this was already done in nametoid. | Jennifer Averett | 2000-01-12 | 1 | -41/+6 |
* | Fixed spacing. | Joel Sherrill | 2000-01-11 | 1 | -1/+1 |
* | This code did not return properly when a process oriented signal | Joel Sherrill | 2000-01-11 | 1 | -6/+5 |
| | | | | was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>. | ||||
* | Removed definition of USHRT_MAX to remove lots of redefinition warnings. | Joel Sherrill | 2000-01-10 | 1 | -2/+0 |
* | Don't look at the object information structure for threads/tasks | Joel Sherrill | 2000-01-10 | 2 | -17/+28 |
| | | | | | for APIs that are not configured. This resulted in weird behavior when ITRON was disabled on some targets. | ||||
* | Corrected spacing. | Joel Sherrill | 2000-01-06 | 1 | -3/+2 |
* | Fixed comment thanks to John M. Mills <jmills@tga.com>. | Joel Sherrill | 2000-01-05 | 1 | -6/+0 |
* | Added support for simple binary semaphores in addition to the high | Joel Sherrill | 2000-01-05 | 16 | -111/+174 |
| | | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority. | ||||
* | Added message priority parameter returned by core support routine. | Joel Sherrill | 2000-01-05 | 1 | -1/+3 |
* | Added new message priority parameter as returned by core support routine. | Joel Sherrill | 2000-01-05 | 1 | -5/+7 |
* | Spacing corrected. | Joel Sherrill | 2000-01-05 | 1 | -1/+1 |
* | Fixed recursive release for mutexes with nesting allowed. | Joel Sherrill | 2000-01-05 | 1 | -1/+4 |
* | + Added return priority from message seize. | Jennifer Averett | 2000-01-05 | 1 | -10/+11 |
| | | | | + Changed priority to be based off of min and max int. | ||||
* | Added the recording of the submit type. | Jennifer Averett | 2000-01-05 | 1 | -0/+1 |
* | + Added return of the message priority. | Jennifer Averett | 2000-01-05 | 1 | -6/+8 |
* | Added priority conversion between POSIX and core. | Jennifer Averett | 2000-01-05 | 1 | -2/+17 |
* | Added priority conversion between POSIX and core priorities. | Jennifer Averett | 2000-01-05 | 1 | -2/+29 |
* | + Changed priority to the POSIX priority type. | Jennifer Averett | 2000-01-05 | 1 | -9/+46 |
| | | | | | | | + Added priority validation + Changed to call correct core routine. + Added priority conversion + Resolved return type problems. | ||||
* | + Added check for reading from a write only queue. | Jennifer Averett | 2000-01-05 | 1 | -1/+12 |
| | | | | + Added ability to return message priority from the core. | ||||
* | + Added check for name greater than PATH_MAX. | Jennifer Averett | 2000-01-05 | 1 | -0/+3 |
* | + Changed to resonable default values for maxmsg and msgsize. | Jennifer Averett | 2000-01-05 | 1 | -3/+11 |
| | | | | + Added oflag tracking. | ||||
* | Added mqueuetranslatereturncode.c. | Jennifer Averett | 2000-01-05 | 1 | -1/+1 |
* | Added routines to translate to and from the core message queue return codes. | Jennifer Averett | 2000-01-05 | 1 | -0/+68 |
* | Added this file to contain an example program. | Joel Sherrill | 2000-01-04 | 1 | -0/+27 |
* | Removed warnings. | Joel Sherrill | 2000-01-04 | 2 | -4/+4 |
* | Removed unitialized variable warning. | Joel Sherrill | 2000-01-04 | 1 | -4/+3 |
* | Increased stack size to 4K per Eric Norum. | Joel Sherrill | 2000-01-03 | 1 | -1/+1 |
* | Increased minimum stack size so all tests will run. | Joel Sherrill | 2000-01-03 | 1 | -1/+1 |
* | + Added routine to remove from namespace. | Jennifer Averett | 1999-12-23 | 1 | -0/+13 |
* | + Added check for name greater than PATH_MAX | Jennifer Averett | 1999-12-23 | 1 | -0/+14 |
* | + Debugged. | Jennifer Averett | 1999-12-23 | 2 | -40/+61 |
* | + Filled in routine. | Jennifer Averett | 1999-12-23 | 1 | -1/+15 |
* | + Initial debug | Jennifer Averett | 1999-12-23 | 1 | -0/+6 |
* | + Made work | Jennifer Averett | 1999-12-23 | 1 | -15/+55 |
| | | | | | + Added checks for valid attribute maxmsg and msgsize + Added check for ENAMETOOLONG | ||||
* | + Fixed errno response to match the POSIX manual. | Jennifer Averett | 1999-12-23 | 1 | -1/+1 |
* | Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to | Joel Sherrill | 1999-12-21 | 1 | -32/+0 |
| | | | | old_exception_processing tree. | ||||
* | Patch rtems-rc-19991203-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-12-21 | 1 | -7/+0 |
| | | | | | | | | | which ontains all what was left over from the other patches (Primarily minor configuration cleanups). To apply: patch -p1 < rtems-rc-19991203-9.diff ./bootstrap | ||||
* | Patch rtems-rc-19991203-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-12-21 | 3 | -23/+29 |
| | | | | | | | | | | | which fixes a nasty dependency bug in optman/Makefile.am. Those directories have been build twice before, i.e. re-running make after having built rtems before, was rebuilding the files in optman/ directories. To apply: patch -p1 < rtems-rc-19991203-6.diff ./bootstrap |
