* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 1 | -21/+0 |
* | Returned third parameter for a NULL name to the objects open call. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 11 | -81/+97 |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | ||||
* | + Modified to use new Thread_Reset routine instead of the restart method. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 12 | -355/+524 |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 9 | -285/+378 |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -37/+27 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 1 | -11/+11 |
| | | | | + Removed error path that should never happen. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -17/+8 |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 1 | -5/+5 |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 1 | -0/+7 |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 1 | -13/+12 |
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -15/+10 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -5/+2 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | Corrected so now actually indexes into the allocation block. | Joel Sherrill | 1999-11-12 | 1 | -10/+6 |
* | Corrected remaining references to struct rtems_task_variable_t since | Joel Sherrill | 1999-11-12 | 2 | -7/+11 |
| | | | | it is now typedef'ed. | ||||
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1999-11-12 | 1 | -0/+13 |
* | Used typedef so all "struct rtems_task_variable_t" uses are now | Joel Sherrill | 1999-11-12 | 4 | -19/+19 |
| | | | | just "rtems_task_variable_t". | ||||
* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 1 | -4/+36 |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | ||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 4 | -4/+224 |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | ||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 1 | -243/+239 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 |
* | Corrected to account for the way memory is divided up in | Joel Sherrill | 1999-11-10 | 1 | -7/+9 |
| | | | | | _Object_Extend_information. This change is a side-effect of the change made to that file to fix an alignment problem. | ||||
* | Added line to make sure HAS_ITRON_API is defined in Makefile. | Joel Sherrill | 1999-11-10 | 1 | -2/+1 |
* | Added call to _Thread_Enable_dispatch() and did some cleanup. | Joel Sherrill | 1999-11-10 | 1 | -2/+9 |
* | Patch from Eric Norum <eric@cls.usask.ca> which includes: | Joel Sherrill | 1999-11-10 | 3 | -8/+163 |
| | | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP. | ||||
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 33 | -136/+695 |
| | | | | Working Group. Included are tests. | ||||
* | Commented out single letter type names since they conflict with | Joel Sherrill | 1999-11-09 | 1 | -0/+6 |
| | | | | numerous other uses of the same variable. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 104 | -41/+8175 |
| | | | | for RTEMS. | ||||
* | Fixed warning where initialized default POSIX API structure did | Joel Sherrill | 1999-11-09 | 1 | -0/+2 |
| | | | | have have semaphores and message queue fields. | ||||
* | Removed unused variable warning. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 |
* | Added imfs_unixstub.c to satisfy linker problems on UNIX port. | Joel Sherrill | 1999-11-09 | 1 | -0/+71 |
* | sem_close was accidentally lost in the split. | Joel Sherrill | 1999-11-09 | 2 | -1/+48 |
* | Patch from Eric Norum <eric@cls.usask.ca> to add NTP BOOTP support because | Joel Sherrill | 1999-11-09 | 3 | -1/+48 |
| | | | | | | | | EPICS needs a synchronized time-of-day clock. This patch is the changes needed to get NTP server information from a BOOTP server. This patch also adds NTP server information to the network configuration structure, too. | ||||
* | Correctly set and called handlers table for the link. | Jennifer Averett | 1999-11-05 | 1 | -1/+3 |
* | Fixed comment | Jennifer Averett | 1999-11-05 | 1 | -1/+1 |
* | Moved imfs set handlers prototype to the imfs.h file. | Jennifer Averett | 1999-11-05 | 2 | -6/+4 |
* | New file. | Joel Sherrill | 1999-11-05 | 1 | -0/+38 |
* | Unmount was failing as a side-effect of splitting the rmnod handler | Joel Sherrill | 1999-11-05 | 7 | -63/+102 |
| | | | | and not handling every case properly. | ||||
* | Split unistd.c file into sysconf.c and sleep.c. | Joel Sherrill | 1999-11-05 | 3 | -2/+29 |
* | Following comments from Eric Norum <eric@cls.usask.ca>, a fairly | Joel Sherrill | 1999-11-05 | 3 | -285/+260 |
| | | | | | | | substantial upgrade of newlibc.c occurred. Now the user extension data area is used rather than notepads and as many routines as possible were split into other files further reducing the minimum footprint of an RTEMS executable. | ||||
* | Fixed typo. | Joel Sherrill | 1999-11-05 | 1 | -3/+3 |
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 17 | -5/+241 |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 4 | -3/+54 |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | ||||
* | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 1999-11-03 | 5 | -8/+9 |
| | | | | internal symbols are supposed to have leading underscores. | ||||
* | Added CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM as a configuration | Joel Sherrill | 1999-11-03 | 1 | -4/+3 |
| | | | | parameter. | ||||
* | Added prototype of _POSIX_Semaphore_Delete to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 |
* | Added prototype of POSIX_Thread_cancel_run to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 |
* | Split core mutex and semaphore handlers into separate files. | Joel Sherrill | 1999-11-02 | 6 | -0/+561 |
