* | Web server uses the POSIX API. Therefor, it must be disabled when the | Joel Sherrill | 1999-11-16 | 1 | -1/+5 |
| | | | | POSIX API is disabled. | ||||
* | Removed start subdirectory and distributed contents to the appropriate | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
| | | | | places under the libbsp tree. | ||||
* | Added comments. | Joel Sherrill | 1999-11-16 | 3 | -3/+10 |
* | Now use _Thread_Reset(). | Joel Sherrill | 1999-11-16 | 1 | -19/+4 |
* | Added threadreset.c. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added prototype for _Thread_Reset() and numerous comments. | Joel Sherrill | 1999-11-16 | 1 | -4/+28 |
* | Only check for System V IPC if multiprocessing is enabled. The unix | Joel Sherrill | 1999-11-16 | 3 | -2/+15 |
| | | | | | | | | port only uses System V IPC for shared memory and semaphores to communicate between nodes in a multiprocessor configuration. If you disable multiprocessing, then this code should be unused. Thus systems like Cygwin which are POSIX but do not support System V IPC should not work. | ||||
* | Fixed so can be included multiple times in the executive source. | Joel Sherrill | 1999-11-16 | 1 | -0/+9 |
* | Works now. | Joel Sherrill | 1999-11-16 | 2 | -38/+24 |
| | | | | | Removed times() since the version in the C Library support code is fine. | ||||
* | Return a reasonable error other than ENOSYS. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added call to _Watchdog_Remove to remove the sporadic timer. It was | Joel Sherrill | 1999-11-16 | 1 | -0/+1 |
| | | | | being reinserted onto the ticks chain. | ||||
* | Moved utsname from "build for now" (unimplemented files) to the main | Joel Sherrill | 1999-11-16 | 1 | -4/+5 |
| | | | | list of C_PIECES since it is now implemented. | ||||
* | Comment fixed when adding prototype for | Joel Sherrill | 1999-11-16 | 1 | -2/+11 |
| | | | | _ITRON_Message_buffer_Translate_core_message_buffer_return_code. | ||||
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+66 |
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+113 |
* | Added. | Joel Sherrill | 1999-11-16 | 5 | -0/+205 |
* | Source and destination arguments to strncpy were swapped. This mistake | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
| | | | | was made in the conversion of bcopy() to strncpy(). | ||||
* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 1 | -21/+0 |
* | Returned third parameter for a NULL name to the objects open call. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 11 | -81/+97 |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | ||||
* | + Modified to use new Thread_Reset routine instead of the restart method. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 12 | -355/+524 |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 9 | -285/+378 |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -37/+27 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 1 | -11/+11 |
| | | | | + Removed error path that should never happen. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -17/+8 |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 1 | -5/+5 |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 1 | -0/+7 |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 1 | -13/+12 |
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -15/+10 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -5/+2 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | Corrected so now actually indexes into the allocation block. | Joel Sherrill | 1999-11-12 | 1 | -10/+6 |
* | Corrected remaining references to struct rtems_task_variable_t since | Joel Sherrill | 1999-11-12 | 2 | -7/+11 |
| | | | | it is now typedef'ed. | ||||
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1999-11-12 | 1 | -0/+13 |
* | Used typedef so all "struct rtems_task_variable_t" uses are now | Joel Sherrill | 1999-11-12 | 4 | -19/+19 |
| | | | | just "rtems_task_variable_t". | ||||
* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 1 | -4/+36 |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | ||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 4 | -4/+224 |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | ||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 1 | -243/+239 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 |
* | Corrected to account for the way memory is divided up in | Joel Sherrill | 1999-11-10 | 1 | -7/+9 |
| | | | | | _Object_Extend_information. This change is a side-effect of the change made to that file to fix an alignment problem. | ||||
* | Added line to make sure HAS_ITRON_API is defined in Makefile. | Joel Sherrill | 1999-11-10 | 1 | -2/+1 |
* | Added call to _Thread_Enable_dispatch() and did some cleanup. | Joel Sherrill | 1999-11-10 | 1 | -2/+9 |
* | Patch from Eric Norum <eric@cls.usask.ca> which includes: | Joel Sherrill | 1999-11-10 | 3 | -8/+163 |
| | | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP. | ||||
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 33 | -136/+695 |
| | | | | Working Group. Included are tests. | ||||
* | Commented out single letter type names since they conflict with | Joel Sherrill | 1999-11-09 | 1 | -0/+6 |
| | | | | numerous other uses of the same variable. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 104 | -41/+8175 |
| | | | | for RTEMS. | ||||
* | Fixed warning where initialized default POSIX API structure did | Joel Sherrill | 1999-11-09 | 1 | -0/+2 |
| | | | | have have semaphores and message queue fields. | ||||
* | Removed unused variable warning. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 |
* | Added imfs_unixstub.c to satisfy linker problems on UNIX port. | Joel Sherrill | 1999-11-09 | 1 | -0/+71 |
