that switches the sparc from targopts.h to cpuopts.h.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
that removes an unnecessary inclusion of @RTEMS_BSP@.cfg.
This update addresses the following:
+ the ISR enable/disable/flash macros now work with old gcc versions.
+ the UI CCR bits are now masked since other example code did so
+ _ISR_Dispatch disables interrupts during call setup
Together these removed the instabilities he was seeing.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
using cpuopts.h and not targopts.h.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
that addresses aspects of the targopts.h multilib related
issues.
* Move targopts.h to libbsp/include, because the current targopts.h
actually is a per-BSP-header and therefore can not stay below exec/.
* Introduce an autoheader generated header file
(exec/score/include/rtems/score/cpuopts.h), which shall take per-cpu
configuration options only.
* Move all autoconf-detectable/configure specified per-cpu
option-defines from targopts.h to cpuopts.h.
* Add Makefiles to the libbsp/shared directory hierarchy.
* The new per-bsp targopts.h in libbsp includes the per-cpu
cpuopts.h. This way, the new targopts.h is kept backward compatible
to the old targopts.h and existing BSPs which (carelessly) include
targopts.h (i386, ppc) should be kept working when using the
multilib-disabled configuration scheme.
* cpuopts.h is not yet complete, because the per-BSP make-targopts
rules from custom/<BSP>.cfg files can not be applied to files below
exec/ when building multilibs.
* All files below exec/ should not include targopts.h anymore, but
should include cpuopts.h instead. However, eliminating inclusion of
targopts.h currently triggers further structural / header file inclusion
related issues, because several ports apply BSP or CPU_MODEL specific
defines from targopts.h below exec/
that is another small step toward multilibs:
* Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/
* Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in
RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme
functional.
* --enable-multilibs is still non-functional
* This patch should not have any influence on the old building
scheme (--disable-multilib should silently fall back to the old
building scheme).
* running ./bootstrap is required after applying the patch
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
where alarm() did not correctly account for the watchdog start_time
and stop_time fields being based on ticks not seconds. This resulted
in alarm() returning a bogus number of seconds remaining.
static inline routine _CORE_mutex_Seize_interrupt_trylock since
static routines are not included when in an application.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
semaphore/mutex can be obtained immediately, this cuts execution time
by 50%.
with interrupts disabled.
if the mutex is successfully obtained.
code remaining here now only blocks.
dispatching -- disabled.
_Interrupt_Manager_initialization.
to be consistent with other ports.
read function in the IMFS properly returns the inode number.
stat()'ing a symbolic link. This is needed to support the port
of the BSD commands like ls to RTEMS.
functionality to libc and update TODO.
Hitachi H8 family. This port was done by Philip Quaife
<philip@qs.co.nz> of Q Solutions and sponsored by
Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1
to a Hitach H8300H. The port was updated to RTEMS 4.5 style
Makefiles/configure by Joel Sherrill <joel@OARcorp.com>.
While doing this Joel added support for the h8300-rtems to
binutils, gcc, newlib, and gdb.
NOTE: Philip submitted a BSP for a Hitachi evaluation board
which is being merged as a separate entity.
