routines.
There seems to be an ugly dependency between posix-headers and
libcsupport.
Configuring rtems with
../rtems-rc-19990324-0/configure \
--target=i386-rtems \
--prefix=<somewhere> \
--disable-posix
"make RTEMS_BSP=pc386" results into:
/opt/rtems/bin/i386-rtems-gcc --pipe
-B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems
-I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall
-ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c
In file included from
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16:
/opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or
directory
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning:
`struct utimbuf' declared inside parameter list
its scope is only this definition or declaration,
which is probably not what you want.
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function
`utime':
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34:
dereferencing pointer to incomplete type
make[4]: *** [o-pc386/utime.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c'
make: *** [all] Error 1
Apparently sys/utime.h is one of the posix headers and therefore gets
not installed (I suppose this is correct).
IMO, this probably indicates that sys/utime.h has to be moved to another
include subdirectory and should not be part of the posix-package.
[AFAIK, sys/*.h are system dependent headers, so why should it be a
posix-header? - Hmm]
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
by Jiri Gaisler <jgais@ws.estec.esa.nl>.
network interface names. This change does not introduce any
compatibility problems.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
2 lines of code that did not get included when Joel tried to manually
add a rejected patch.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
fcntl support and an external fcntl handler for sockets.
are:
calculated.
would work. At the same time, the initial implementation of F_SETFL
was added. A support routine was added to convert internal libio
flags back to the POSIX style. Eventually the internal representation
should be eliminated in the interest of simplicity and code reduction.
This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory
too fast. Perhaps in the future, the places in IMFS that put a maximum
length name string on the stack and the jnode structure does not include
a maximu length name string can be fixed so this is not a problem.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> 3) rtems-rc-19990131-2.diff
> now)
> patches will apply then ;-.
> 2) rtems-rc-19990131-1.diff
> Rework of compilers/*.cfg files (esp. gcc-target-default.cfg) to adapt
> the flags/makefile variables to automake and make standards (cf.
> make.info - implicit rules/variables).
> This patch is rather risky and may probably break things, but is an
> essential step towards automake.
> FWIW: It also reverts the i386-ASMFLAGS/ASFLAGS-patch, which was wrong,
> as I had to experience ;-.
To achieve this:
been removed.
You will find enclosed a patch which contains, for Intel PC386 target :
- an Ethernet driver for DEC21140 device based boards.
- a simple cache management with paging mechanism.
based board.
that added ifdef on the pc386.
