path: root/c/src/exec/wrapup/rtems/Makefile.in (follow)
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-1/+1
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Changed invocation of size_rtems to match new autoconf'ed version.Joel Sherrill1997-12-221-1/+1
* Added lines to build sizeinfo.txt which is automatically generated nowJoel Sherrill1997-12-221-0/+3
| | | | by size_rtems.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+48
