* configure.ac: Use AS_IF instead of if/then/else.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix.
Add include/Makefile to CONFIG_FILES.
Add AC_ENABLE_MULITLIB.
Remove wrapup/rtems, wrapup/itron, wrapup/posix.
Remove */optman/Makefile from CONFIG_FILES.
* Makefile.am: Add include to SUBDIRS.
* rtems/Makefile.am: Remove optman from SUBDIRS.
* sapi/Makefile.am: Remove optman from SUBDIRS.
* include/Makefile.am: New file.
* include/rtems/bspIo.h: Relocated from lib/include.
* include/rtems/libio_.h: Relocated from lib/include.
* wrapup/posix/Makefile.am: Add multilib support.
* wrapup/itron/Makefile.am: Add multilib support.
* wrapup/rtems/Makefile.am: Add multilib support.
* Makefile.am: Add multilib support.
* wrapup/itron/Makefile.am, wrapup/posix/Makefile.am,
wrapup/rtems/Makefile.am: Include compile.am
