bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
bugs.
./bootstrap
Known bugs:
moment.
Synthesizer Control Register to remove use of single letter names.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
<corsepiu@faw.uni-ulm.de> to correct the constraints on the
inline assembly language macro for sh_disable_interrupt.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
its name in the name_table. This was required by the POSIX semaphore
and message queue managers which support a concept of open, close, and
unlink. The object becomes "invisible" to further opens following an
unlink but all open sessions remain active until they are closed. This
requires that the removal of an object ID be separate from the removal
of its name.
RTEMS API extension to avoid problems when the extension is freed.
Eventually the task variable switch extension should become part
of the core context switch and the Ada tcb self implemented in
terms of it.
port only uses System V IPC for shared memory and semaphores to
communicate between nodes in a multiprocessor configuration. If you
disable multiprocessing, then this code should be unused. Thus systems
like Cygwin which are POSIX but do not support System V IPC should
not work.
_Object_Extend_information. This change is a side-effect of the
change made to that file to fix an alignment problem.
for RTEMS.
BSP needs to be eliminated.
being allocated. This bug manifested itself on the SPARC
since it uses ldd/std in its context save/restore routines.
based thread queue were to be reinserted based on its new priority,
this is where the logic would go.
by ITRON.
Corrected spacing.
<mark@ramix.com> of RAMIX.
disabled on exit to ISR Thread dispatching. This allows a
context switch to finish under high high interrupt rates.
running the network stack.
and not likely to become so. Comments on each configuration
are below.
+ Force CPU386 - This BSP was developed as part of the initial
port of RTEMS to the i386. This board has been unavailable
for a long time now.
+ GO32 - This BSP and some CPU code supported djgpp v1.x. This
version is now quite old. No one has stepped forward to
update the code to v2.x which may be technically impossible
anyway. More importantly, go32 has been superceded by the pc386 BSP.
sigemptyset(&old_mask) needed to be added on glibc2 systems. Ian
Lance Taylor pointed out that sigemptyset() is portable so Joel removed
all conditionals around calls to sigemptyset().
