1996-04-19 | changes to compile in macro configuration without warnings. | Joel Sherrill | 6 | -4/+48 | |
1996-03-21 | *** empty log message *** | Joel Sherrill | 3 | -8/+4 | |
1996-03-21 | updated for 68302 and so gen68360 bsp would compile | Joel Sherrill | 2 | -1/+13 | |
1996-03-06 | Added 68360 support submitted by W. Eric Norum (eric@skatter.usask.ca). | Joel Sherrill | 2 | -2/+12 | |
Also increased minimum stack size from 1K to 2K. | |||||
1996-03-06 | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 85 | -4673/+1624 | |
the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | |||||
1996-03-06 | Removed prototyes for static inline rgutines and moved the comments into | Joel Sherrill | 1 | -41/+2 | |
1996-02-21 | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 16 | -17/+778 | |
the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized. | |||||
1996-02-21 | Dispersal of internal thread handler resulted in IDLE thread becoming | Joel Sherrill | 11 | -52/+49 | |
part of the Thread Handler. This required the name of the optional CPU dependent IDLE thread implementation to change. | |||||
1996-02-14 | Removed arguments from _Thread_Start_multitasking. | Joel Sherrill | 2 | -8/+2 | |
1996-02-14 | removed arguments from _Thread_Start_multitasking | Joel Sherrill | 1 | -12/+10 | |
1996-02-14 | white space problem | Joel Sherrill | 1 | -1/+0 | |
1996-02-13 | changed post task extension from user set to api set and added flag | Joel Sherrill | 12 | -113/+67 | |
in each thread which must be set when the post switch extension is to be run. | |||||
1996-02-13 | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1 | -1/+4 | |
1996-02-13 | more comments added and existing ones cleaned up in synchronization paths | Joel Sherrill | 1 | -1/+13 | |
1996-02-13 | comma removed from end of last enumerated element | Joel Sherrill | 2 | -2/+2 | |
1996-02-09 | new isr synchronization algorithm using a single enumerated set of states. | Joel Sherrill | 7 | -52/+79 | |
1996-02-09 | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 2 | -0/+2 | |
1996-02-08 | alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT | Joel Sherrill | 2 | -2/+2 | |
1996-02-01 | Swapped order of nested acquisition check and check for returning unsatisfied. | Joel Sherrill | 1 | -6/+6 | |
1996-02-01 | synchronization state bugs address | Joel Sherrill | 1 | -7/+12 | |
1996-02-01 | invalid use of tcb field resource count | Joel Sherrill | 1 | -1/+0 | |
1996-01-17 | added class to initial id macro | Joel Sherrill | 2 | -8/+6 | |
1996-01-17 | increased stack size | Joel Sherrill | 1 | -1/+1 | |
1996-01-15 | Made real body of _Heap_Walk conditional on RTEMS_DEBUG. This is necessary | Joel Sherrill | 1 | -0/+13 | |
to be able to build a system without requiring printf. | |||||
1996-01-15 | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 15 | -174/+258 | |
1995-12-20 | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 14 | -105/+160 | |
partially recovered working tree, etc | |||||
1995-12-19 | changes remerged after disk crash -- history lost | Joel Sherrill | 2 | -2/+2 | |
1995-12-08 | added correct use of _Thread_queue_Enter_critical_section | Joel Sherrill | 4 | -4/+4 | |
1995-12-05 | Added comments for addition of is_fp flag to _CPU_Context_Initialize. | Joel Sherrill | 1 | -0/+5 | |
1995-12-05 | minor changes so it would compile in a cross environment | Joel Sherrill | 1 | -0/+2 | |
1995-12-05 | minor changes so it would compile | Joel Sherrill | 4 | -14/+12 | |
1995-12-01 | Insert mode argument to _Watchdog_Insert removed. Now are watchdog timers | Joel Sherrill | 10 | -84/+26 | |
are automatically activated upon insertion. | |||||
1995-12-01 | Added new synchronization algorithm. | Joel Sherrill | 1 | -58/+92 | |
1995-12-01 | Added support for new synchronization algorithm. Specifically, the routine | Joel Sherrill | 2 | -0/+28 | |
_Thread_queue_Enter_critical_section was added. | |||||
1995-12-01 | Added support for new synchronization algorithm. | Joel Sherrill | 2 | -0/+50 | |
1995-12-01 | Corrected use of the state WATCHDOG_REINSERT and renamed it | Joel Sherrill | 3 | -14/+27 | |
WATCHDOG_BEING_INSERTED. | |||||
1995-10-31 | typos fixed | Joel Sherrill | 8 | -8/+105 | |
1995-10-30 | SPARC port passes all tests | Joel Sherrill | 35 | -877/+2451 | |
1995-10-06 | fixed null pointer dereference | Joel Sherrill | 1 | -2/+2 | |
1995-10-06 | fixed missing CVS IDs | Joel Sherrill | 15 | -6/+28 | |
1995-10-06 | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 8 | -1/+1866 | |
1995-10-06 | moved to new development machine and went to gcc 2.7.0 | Joel Sherrill | 1 | -0/+3 | |
1995-09-29 | all targets compile .. tony's patches in place | Joel Sherrill | 14 | -48/+113 | |
1995-09-27 | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 3 | -19/+455 | |
stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | |||||
1995-09-27 | Fixed typo | Joel Sherrill | 2 | -4/+4 | |
1995-09-26 | posix support initially added | Joel Sherrill | 119 | -415/+688 | |
1995-09-22 | Removed unnecessary include files. | Joel Sherrill | 1 | -1/+1 | |
1995-09-22 | Removed unneeded referenced to rtems/fatal.h | Joel Sherrill | 6 | -6/+0 | |
1995-09-21 | More file movement required api extension to be added to score | Joel Sherrill | 3 | -0/+256 | |
1995-09-21 | More file movement | Joel Sherrill | 5 | -9/+7 | |
