path: root/c/src/exec/score (unfollow)
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-52/+76
* src/coremutex.c, src/coremutexseize.c, src/coremutexsurrender.c, inline/rtems/score/coremutex.inl: The per thread field resource_count should only be manipulated when a mutex is priority ceiling or priority inherit. This was reported by Chris Johns <ccj@acm.org> who also noticed that the use of switches for all disciplines generated less efficient code than using explicit tests for the one or two cases we were really interested in. Further review of his modifications made it apparent that the "isa" methods to test mutex discipline were not being used so this modification was swept into the code as well.
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+7
* src/coremutexseize.c: Add missing code for proper handling of nesting acquisitions. This only impacts building with inlines disabled on the source with the "fast mutex" optimizations. This was post the 4.5 branch and did not impact released versions.
2001-08-162001-07-25 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2-1/+10
* cpu.c (_CPU_ISR_install_vector): Corrected interrupt range checking which was SH1 specific. It didn't work for SH2 (has more interrupt sources).
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+7
* src/coremutexsurrender.c: Use holder thread not executing thread because even though they may and often are the same it is not guaranteed unless the proper attribute is set.
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+11
* include/rtems/score/coremsg.h, src/coremsgsubmit.c: Add a new return status to account for blocking sends. Otherwise, the caller will think that the returned message status will have the ultimate results of the operation. If the send times out, the final status will be in the return_code of the thread.
2001-08-092001-08-09 Chris Johns <ccj@acm.org>Joel Sherrill2-63/+48
* cpu_asm.S: This patch was co-developed with Eric Norum <eric.norum@usask.ca>. It closes a one instruction window on some m68k CPU cores. It fixes symptoms seen as: 1) No more `interrupt handler invoked twice for a single interrupt'. 2) No more `lockup when mc68360 CPM and PIT interrupts are at different levels'. It does insert a little more overhead on machines without hardware interrupt stacks but correctness has a price.
2001-08-092001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-29/+50
* include/rtems/score/coremsg.h, inline/rtems/score/coremsg.inl, src/coremsgsubmit.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
2001-07-032001-07-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+5
* cpu.c: Fixed typo.
2001-05-252000-05-25 Sergei Organov <osv@javad.ru>Joel Sherrill3-2/+6
* macros/rtems/score/coresem.inl, inline/rtems/score/coresem.inl: Cut and paste problem incorrectly enabled interrupts twice with the first time being too early.
2001-05-242000-05-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-7/+38
* rtems/score/mips.h: Added constants for MIPS exception numbers. All exceptions should be given low numbers and thus can be installed and processed in a uniform manner. Variances between various MIPS ISA levels were not accounted for.
2001-05-242000-05-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+7
2001-05-242001-05-24 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-57/+157
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>. * cpu_asm.S: Now works on Mongoose-V. Missed in previous patch.
2001-05-222001-05-22 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill3-21/+86
* rtems/score/cpu.h: Add the interrupt stack structure and enhance the context initialization to account for floating point tasks. * rtems/score/mips.h: Added the routines mips_set_cause(), mips_get_fcr31(), and mips_set_fcr31(). * Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
2001-05-092001-05-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-0/+9
* include/rtems/score/.cvsignore: Add stamp-h, cpuopts.h, cpuopts.h.in, cpuopts-tmp.h.
2001-05-082001-05-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-2/+4
* rtems/score/cpu.h: Remove #undef __STRICT_ANSI__.
2001-05-072001-05-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-67/+95
* cpu_asm.S: Merged patches from Gregory Menke <Gregory.D.Menke.1@gsfc.nasa.gov> that clean up stack usage and include nops in the delay slots.
2001-04-202001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+15
* cpu_asm.S: Added code to save and restore SR and EPC to properly support nested interrupts. Note that the ISR (not RTEMS) enables interrupts allowing the nesting to occur.
2001-04-112001-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+4
* cpu.c: Removed duplicate declaration for _ISR_Vector_table.
2001-03-142001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-96/+59
* cpu.c, rtems/score/cpu.h, rtems/score/mipstypes.h: Removed unused variable _CPU_Thread_dispatch_pointer and cleaned numerous comments.
2001-03-142001-03-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-722/+405
* cpu.c, cpu_asm.S, iregdef.h, rtems/score/cpu.h, rtems/score/mips.h: Merged MIPS1 and MIPS3 code reducing the number of lines of assembly. Also reimplemented some assembly routines in C further reducing the amount of assembly and increasing maintainability.
2001-02-052001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill49-113/+191
* Makefile.am, rtems/score/Makefile.am: Apply include_*HEADERS instead of H_FILES.
2001-02-052001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-14/+28
* include/rtems/Makefile.am, include/rtems/score/Makefile.am, inline/rtems/score/Makefile.am, macros/rtems/score/Makefile.am Apply include_*HEADERS instead of H_FILES.
2001-01-292001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+7
* src/objectextendinformation.c: Added include of string.h to eliminate warning.
2001-01-252001-01-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-6/+16
* cpu.c, rtems/score/cpu.h: Bug report from Peter Mueller <peter.o.mueller@gmx.de> because of not correcting for the ISR vector table now being allocated from the workspace.
2001-01-122001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+7
* rtems/score/mips.h (mips_get_sr, mips_set_sr): Corrected register constraints from "general" to "register".
2001-01-092001-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-6/+27
* cpu_asm.S: Use SR_INTERRUPT_ENABLE_BITS instead of SR_XXX constants to make it easier to conditionalize the code for various ISA levels.
2001-01-082001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+9
* src/threadinitialize.c: Fix my bad hack of Ralf's fp_area warning removal patch. :(
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-0/+6
* src/threadinitialize.c: Removed warning.
2001-01-082001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-3/+16
* idtcpu.h: Commented out definition of "wait". It was stupid to use such a common word as a macro. * rtems/score/cpu.h (_CPU_ISR_Disable): Fixed for mips ISA 3. * rtems/score/mips.h: Added include of <idtcpu.h>. * rtems/score/mips.h (mips_enable_in_interrupt_mask): Corrected.
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill14-6/+99
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill12-7/+61
* rtems/score/cpu.h: Added _CPU_Initialize_vectors(). * cpu_asm.S: Modify to properly dereference _ISR_Vector_table now that it is dynamically allocated.
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-7/+20
* rtems/score/cpu.h: Added _CPU_Initialize_vectors(). * cpu_asm.S: Eliminated warning for duplicate definition of EXTERN.
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-3/+13
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-4/+0
* ChangeLog: Removed duplicate entry.
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-0/+28
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+10
2000-12-192000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-4/+9
* src/isr.c: Allocate the _ISR_Vector_table all the time not just when we are allocating an interrupt stack.
2000-12-192000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+9
* cpu_asm.S (_ISR_Handler): Return to the address in the EPC register. Previous code resulting in the interrupted immediately returning to the caller of the routine it was inside.
2000-12-192000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-11/+5
* cpu.c (_CPU_Initialize): Do not initialize _ISR_Vector_table() here because it has not been allocated yet.
2000-12-192000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+8
* cpu.c: Do not read or write raw interrupt vector table if we are on a CPU that does not have a %vbr register and the BSP is configured as having the table in ROM.
2000-12-132000-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-1/+11
* include/rtems/score/isr.h, src/isr.c: Allocate it from the workspace rather than explicitly declaring it. This allows the size to be a non-constant from the perspective of score/cpu.
2000-12-132000-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-82/+16
* cpu.c: Removed duplicate declaration for _ISR_Vector_table. * cpu_asm.S: Removed assembly language to vector ISR handler on MIPS ISA I. Now call mips_vector_isr_handlers() in libcpu or BSP. * rtems/score/cpu.h (CPU_INTERRUPT_NUMBER_OF_VECTORS): No longer a constant -- get the real value from libcpu.
2000-12-132000-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill12-713/+281
* cpu_asm.h: Removed. * Makefile.am: Remove cpu_asm.h. * rtems/score/mips64orion.h: Renamed mips.h. * rtems/score/mips.h: New file, formerly mips64orion.h. Header rewritten. (mips_get_sr, mips_set_sr, mips_enable_in_interrupt_mask, mips_disable_in_interrupt_mask): New macros. * rtems/score/Makefile.am: Reflect renaming mips64orion.h. * asm.h: Include <mips.h> not <mips64orion.h>. Now includes the few defines that were in <cpu_asm.h>. * cpu.c (_CPU_ISR_Get_level): Added MIPS ISA I version of this routine. MIPS ISA 3 is still in assembly for now. (_CPU_Thread_Idle_body): Rewrote in C. * cpu_asm.S: Rewrote file header. (FRAME,ENDFRAME) now in asm.h. (_CPU_ISR_Get_level): Removed ISA I version and rewrote in C. (_CPU_ISR_Set_level): Removed ISA I version and rewrote in C. (_CPU_Context_switch): MIPS ISA I now manages preserves SR_IEC and leaves other bits in SR alone on task switch. (mips_enable_interrupts,mips_disable_interrupts, mips_enable_global_interrupts,mips_disable_global_interrupts, disable_int, enable_int): Removed. (mips_get_sr): Rewritten as C macro. (_CPU_Thread_Idle_body): Rewritten in C. (init_exc_vecs): Rewritten in C as mips_install_isr_entries() and placed in libcpu. (exc_tlb_code, exc_xtlb_code, exc_cache_code, exc_norm_code): Moved to libcpu/mips/shared/interrupts. (general): Cleaned up comment blocks and #if 0 areas. * idtcpu.h: Made ifdef report an error. * iregdef.h: Removed warning. * rtems/score/cpu.h (CPU_INTERRUPT_NUMBER_OF_VECTORS): Now a variable number defined by libcpu. (_CPU_ISR_Disable, _CPU_ISR_Enable): Rewritten to use new routines to access SR. (_CPU_ISR_Set_level): Rewritten as macro for ISA I. (_CPU_Context_Initialize): Honor ISR level in task initialization. (_CPU_Fatal_halt): Use new _CPU_ISR_Disable() macro.
2000-12-062000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+5
* cpu.c: Added include of <rtems/rtems/cache.h> to eliminate warning.
2000-12-062000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+21
* rtems/score/cpu.h: When mips ISA level is 1, registers in the context should be 32 not 64 bits.
2000-12-012000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-15/+21
* macros/rtems/score/coresem.inl: Removed comments since convention calls for comments to be in inline versin. * macros/rtems/score/object.inl (Objects_Get_local_object): Fixed style to use _ prefix on variable names and use parentheses. * macros/rtems/score/object.inl (_Objects_Namespace_remove): Added.
2000-11-302000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill8-6/+145
* General effort to make things compile with macros not inlines * inline/rtems/score/coremutex.inl: Added comment indicating for macros there is another copy of _CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c. * src/coremutexseize.c: Added body of _CORE_mutex_Seize_interrupt_trylock() for macro case. * macros/rtems/score/coremutex.inl: Added prototype for _CORE_mutex_Seize_interrupt_trylock() since there is a real body when macros are enabled. * macros/rtems/score/coresem.inl: Added macro implementation of _CORE_semaphore_Seize_isr_disable. * macros/score/Makefile.am: Fixed typos. * rtems/score/address.inl: Correct macro implementation of _Addresses_Is_aligned() so it would compile. * macros/rtems/score/coremsg.inl: Added closing parentheses.
2000-11-302000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+14
* cpu_asm.S: Changed "_CPU_Ccontext_switch_restore: typo to correct name of _CPU_Context_switch_restore. Added dummy version of exc_utlb_code() so applications would link.
2000-11-282000-11-28 Chris Johns <ccj@acm.org>Joel Sherrill2-1/+18
* src/heapallocate.c: Do not allow the size to overflow when adjusting it. A test allocated a stack of -1 (~0). This actually resulted in a stack being allocated but with a size of 0xb. The allocator did not test the size to see if it rolled through 0 and so allowed the allocation to happen, the thread to get created. The task crashed as you would expect.
