* | renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the Watchdog | Joel Sherrill | 1996-05-31 | 11 | -20/+28 |
| | | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency. | ||||
* | fixed typo in merge of Eric Norum's patch | Joel Sherrill | 1996-05-31 | 1 | -2/+1 |
* | added nanoseconds per second constant | Joel Sherrill | 1996-05-31 | 2 | -2/+4 |
* | corrected minor problem in Eric Norum's changes in the bfffo macro. | Joel Sherrill | 1996-05-31 | 1 | -1/+1 |
* | Added nanoseconds constant | Joel Sherrill | 1996-05-30 | 2 | -4/+6 |
* | Eric Norum sent in new versions of the inline assembly macros which | Joel Sherrill | 1996-05-30 | 2 | -82/+17 |
| | | | | do not generate warnings for unitialized variables. | ||||
* | spacing | Joel Sherrill | 1996-05-29 | 1 | -0/+1 |
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 48 | -150/+204 |
| | | | | score, rtems api, or posix api related. | ||||
* | added enumerated constant for the POSIX API as an error source | Joel Sherrill | 1996-05-28 | 2 | -2/+4 |
* | changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
| | | | | | _ISR_Enable() takes the magic cookie expected by the cpu's status register instead of a simple isr level. | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-05-23 | 3 | -95/+110 |
* | *** empty log message *** | Joel Sherrill | 1996-05-23 | 1 | -2/+2 |
* | invoke thread stack free routine instead of Workspace free. | Joel Sherrill | 1996-05-23 | 1 | -2/+26 |
* | updates from Tony Bennett. | Joel Sherrill | 1996-05-23 | 2 | -60/+78 |
| | | | | | Broke the setjmp/longjmp pair in the context switch into a separate routine so no code depended on local variables surviving the jump. | ||||
* | Modified to correct variables which defined the range of object classes | Joel Sherrill | 1996-05-22 | 2 | -2/+2 |
| | | | | which are tasks. | ||||
* | *** empty log message *** | Joel Sherrill | 1996-05-08 | 1 | -1/+2 |
* | Updates from Eric Norum to use the mcpu32 flags and fix comments. | Joel Sherrill | 1996-05-01 | 2 | -30/+17 |
* | added comment regarding stack alignment issues to thread stack allocation | Joel Sherrill | 1996-04-24 | 1 | -0/+14 |
| | | | | routine. | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -6/+35 |
* | thread.c: added support for optional user provided stack allocator | Joel Sherrill | 1996-04-22 | 2 | -8/+123 |
| | | | | wkspace.c: made initialization routine a regular subroutine | ||||
* | made initialization routine a regular subroutine | Joel Sherrill | 1996-04-22 | 4 | -176/+0 |
* | interr.h: added stack allocater error code | Joel Sherrill | 1996-04-22 | 4 | -2/+30 |
| | | | | wkspace.h: made initialization routine a regular subroutine | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 2 | -31/+71 |
| | | | | | updates from Tony Bennett. Most were to insure all variables were properly initialized and to correct the stray signal number reporting. | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 4 | -18/+16 |
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 3 | -3/+919 |
| | | | | added CPU_M68K_EXTB_L model flag | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 1 | -0/+3 |
* | updartes from Tony Bennett | Joel Sherrill | 1996-04-22 | 4 | -420/+129 |
* | changes to compile in macro configuration without warnings. | Joel Sherrill | 1996-04-19 | 6 | -4/+48 |
* | *** empty log message *** | Joel Sherrill | 1996-03-21 | 3 | -8/+4 |
* | updated for 68302 and so gen68360 bsp would compile | Joel Sherrill | 1996-03-21 | 2 | -1/+13 |
* | Added 68360 support submitted by W. Eric Norum (eric@skatter.usask.ca). | Joel Sherrill | 1996-03-06 | 2 | -2/+12 |
| | | | | Also increased minimum stack size from 1K to 2K. | ||||
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 85 | -4673/+1624 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Removed prototyes for static inline rgutines and moved the comments into | Joel Sherrill | 1996-03-06 | 1 | -41/+2 |
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 16 | -17/+778 |
| | | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized. | ||||
* | Dispersal of internal thread handler resulted in IDLE thread becoming | Joel Sherrill | 1996-02-21 | 11 | -52/+49 |
| | | | | | part of the Thread Handler. This required the name of the optional CPU dependent IDLE thread implementation to change. | ||||
* | Removed arguments from _Thread_Start_multitasking. | Joel Sherrill | 1996-02-14 | 2 | -8/+2 |
* | removed arguments from _Thread_Start_multitasking | Joel Sherrill | 1996-02-14 | 1 | -12/+10 |
* | white space problem | Joel Sherrill | 1996-02-14 | 1 | -1/+0 |
* | changed post task extension from user set to api set and added flag | Joel Sherrill | 1996-02-13 | 12 | -113/+67 |
| | | | | in each thread which must be set when the post switch extension is to be run. | ||||
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-13 | 1 | -1/+4 |
* | more comments added and existing ones cleaned up in synchronization paths | Joel Sherrill | 1996-02-13 | 1 | -1/+13 |
* | comma removed from end of last enumerated element | Joel Sherrill | 1996-02-13 | 2 | -2/+2 |
* | new isr synchronization algorithm using a single enumerated set of states. | Joel Sherrill | 1996-02-09 | 7 | -52/+79 |
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-09 | 2 | -0/+2 |
* | alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT | Joel Sherrill | 1996-02-08 | 2 | -2/+2 |
* | Swapped order of nested acquisition check and check for returning unsatisfied. | Joel Sherrill | 1996-02-01 | 1 | -6/+6 |
* | synchronization state bugs address | Joel Sherrill | 1996-02-01 | 1 | -7/+12 |
* | invalid use of tcb field resource count | Joel Sherrill | 1996-02-01 | 1 | -1/+0 |
* | added class to initial id macro | Joel Sherrill | 1996-01-17 | 2 | -8/+6 |
* | increased stack size | Joel Sherrill | 1996-01-17 | 1 | -1/+1 |
