* rtems/score/h8300types.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/score/c4xtypes.h: Removed.
* rtems/score/a29ktypes.h: Removed.
* cpu.c: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.c).
* cpu.h: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.h).
* sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
* cpu.c: Define fix_syscall_errno() to nothing so MP links.
* cpu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cpu_asm.S: Now compiles on 4600 and 4650.
* cpu_asm.S: Fixed a sneaky return from int w/ ints disabled bug.
* rtems/score/cpu.h: Fixed register numbering in comments and made
interrupt enable/disable more robust.
* rtems/score/m68k.h: m68k_swap_u32 fix typo.
* cpu_asm.S: Added support for the debug exception vector, cleaned
up the exception processing & exception return stuff. Re-added
EPC in the task context structure so the gdb stub will know where
a thread is executing. Should've left it there in the first place...
* idtcpu.h: Added support for the debug exception vector.
* cpu.c: Added ___exceptionTaskStack to hold a pointer to the
stack frame in an interrupt so context switch code can get the
userspace EPC when scheduling.
* rtems/score/cpu.h: Re-added EPC to the task context.
* rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32):
Generic implementation of endian swap primitives added for Coldfire
family.
* cpu_asm.S: Fixed exception return address, modified FP context
switch so FPU is properly enabled and also doesn't screw up the
exception FP handling.
* idtcpu.h: Added C0_TAR, the MIPS target address register used for
returning from exceptions.
* iregdef.h: Added R_TAR to the stack frame so the target address
can be saved on a per-exception basis. The new entry is past the
end of the frame gdb cares about, so doesn't affect gdb or cpu.h
stuff.
* rtems/score/cpu.h: added an #ifdef so cpu_asm.S can include it
to obtain FPU defines without systax errors generated by the C
defintions.
* cpu.c: Improved interrupt level saves & restores.
* rtems/score/cpu.h: Fix conditional to match current GCC.
* configure.ac: Fix the test to determine cpu context size.
* iregdef.h, rtems/score/cpu.h: Reordered register in the
exception stack frame to better match gdb's expectations.
* cpu_asm.S: Enhanced to save/restore more registers on
exceptions.
* rtems/score/cpu.h (CPU_Interrupt_frame): Enhanced to list every
register individually and document when it is saved.
* idtcpu.h: Added constants for the coprocessor 1 registers
revision and status.
* .cvsignore: Added stamp-h.in.
* rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* rtems/score/cpu.h: IDLE task should not be FP. This was a mistake
in the previous patch that has now been confirmed.
* configure.ac: Removed references to rtems/Makefile and
* cpu.c: Enhancements and fixes for modifying the SR when changing
the interrupt level.
* cpu_asm.S: Fixed handling of FP enable bit so it is properly
managed on a per-task basis, improved handling of interrupt levels,
and made deferred FP contexts work on the MIPS.
* rtems/score/cpu.h: Modified to support above changes.
* Makefile.am: Reflect 2002-01-23 changes.
* rtems/Makefile.am: Removed.
* Makefile.am: Corrected so .h files from rtems/score/ are installed.
* Makefile.am: Reflect changes from 2002-01-23.
* include/rtems/score/watchdog.h: Added WATCHDOG_MAXIMUM_INTERVAL.
AC_CONFIG_SRCDIR(asm.h).
* Makefile.am: Merge in rtems/Makefile.am and
rtems/score/Makefile.am. Remove gensize. Require automake-1.5.
* rtems/score/.cvsignore: Add unixsize.h*. Add stamp-h*.
* configure.ac: Add AM_CONFIG_HEADER(rtems/score/unixsize.h).
* rtems/score/cpu.h: Replace CPU_CONTEXT_SIZE_IN_BYTES with
SIZEOF_CPU_CONTEXT.
* rtems/Makefile.am: New.
* rtems/.cvsignore: New.
* rtems/score/Makefile.am: New.
* rtems/score/.cvsignore: New.
* rtems/score/ppc.h: Relocated from shared/.
* rtems/score/ppctypes.h: Relocated from shared/.
* asm.h: Relocated from shared/.
* shared/Makefile.am: Removed.
* shared/asm.h: Removed.
* shared/ppc.h: Removed.
* shared/ppctypes.h: Removed.
* shared/.cvsignore: Removed.
* include/rtems/system.h: Fix typo in yesterday's change:
RTEMS_MULTILIBS.
* include/rtems/system.h: Only include cpuopts.h when building a
multilib configuration. Some ports still need targopts.h but this
small modification lets those ports work non-multilib while
fixing being fixed for multilib.
* asm.h: Remove #include <rtems/score/targopts.h>.
Add #include <rtems/score/cpuopts.h>.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* rtems/score/cpu.h: #include <rtems/bspIo.h>.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* cpu.c: Include rtems/bspIo.h instead of bspIo.h.
* include/rtems/seterr.h: Add do {..} while (0) in defines.
Rename set_errno_and_return_minus_one into
rtems_set_errno_and_return_minus_one.
* configure.ac: Use RTEMS_ENV_RTEMSCPU.
* inline/rtems/score/object.inl, macros/rtems/score/object.inl: Add
add casts to Objects_Id in _Objects_Build_ids to avoid implicit
typecasts from enum to int16 on bit16 targets (here: h8300).
* src/Makefile.am: Add multilib support.
* Makefile.am: Add multilib support.
* asm.h: include cpuopts.h instead of targopts.h
* rtems/score/arm.h: Use __arm__.
This was tracked as PR91.
* include/rtems/score/isr.h, inline/rtems/score/isr.inl,
macros/rtems/score/isr.inl: Modified to allow any port to provide
its own implementation of the macro _ISR_Is_in_progress. If the
port overrides this macro, it must provide a non-inlined function
implementation.
