path: root/c/src/exec/score/tools/hppa1.1/configure (unfollow)
1999-07-23Tools moved to top-level directory per patch from Ralf Corsepius ↵Joel Sherrill1-1452/+0
<corsepiu@faw.uni-ulm.de>.
1999-06-16Patcg from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-29/+24
-- configure now fails to detect the toolchain for linux-posix. As work-around, I have reverted to the old behavior of RTEMS_TARGET_CPU_NAME, thus no_cpu/no_bsp will fail badly in configure again.
1999-06-15Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-18/+20
> When I run my script that just repeatedly builds different targets, some > of them die with an error like this: > > Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@ > /bin/sh: @RTEMS_CPU@: No such file or directory > gmake[5]: *** [all] Error 1 > gmake[5]: Leaving directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > > It is not always the same variable substitution that fails. Sometimes it > is @INSTALL@. But reliably, it is a variable substitution that is > failing. > > Do you have any idea why this happens? Yep, I think I know what's going on. AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in target.cfg.in doesn't get substituted correctly, causing the bug above. Due to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected. Other similar problems probably exist for the unix/posix bsp and the hppa.1 cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too.
1999-06-14Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-35/+36
This patch should fix the nastiest configuration bugs for no_cpu/no_bsp. With this patch applied, configure --target=no_cpu-rtems now correctly acknowledges its configuration, but later fails building when trying to build libcsupport (I leave this problem for you :-). Fixes/Changes: * aclocal/canonicalize-target-name.m4: use RTEMS_CPU instead of target_cpu, switch to a native compiler setup if target = no_cpu*rtems, ie. implicitly use host=target (native) and RTEMS_CPU=no_cpu for --target=no_cpu*rtems. * add no_bsp/bsp_specs (Support -qrtems, -qrtems_debug; please check before adding :-) * Use RTEMS_CANONICALIZE_TARGET_CPU instead of AC_CANONICAL_SYSTEM in toplevel/configure.in * All references to $target_cpu in aclocal/*.m4, Makefile.ins and *.cfg files changed to RTEMS_CPU * bug fixes to exec/score/cpu/no_cpu/wrap (This part of the patch may result into patch rejections, because your recently posted patch may also have addressed this problem). After applying this patch, please do: cvs add c/src/lib/libbsp/no_cpu/no_bsp/bsp_specs ./autogen
1999-05-27Regenerated.Joel Sherrill1-51/+113
1999-05-18Regenerated.Joel Sherrill1-113/+51
1999-04-12Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-89/+176
This patch addresses a few minor issues and contains a few (minor) preparations for automake. * configure.in: Fix for handing c/src/tests subdirectory handling (FIX) * aclocal/rtems-top.m4: + Add TARGET_SUBDIR and --with-target-subdir (preparation of future enhancements for cross-compiling) + Activate RTEMS_ROOT handling (automake preparation) * automake/*.am: replace comments "#" with "##" so that comments won't get included into Makefile.in's anymore * c/update-tools/* automake support (NEW) * ./autogen update/enhancement (cf. ./autogen for details) After applying this patch please run: ./autogen cvs add c/update-tools/configure.in cvs add c/update-tools/Makefile.am cvs add c/update-tools/aclocal.m4
1999-03-31Regenerated.Joel Sherrill1-161/+89
1999-03-24These files were not added as part of a recent patch fromJoel Sherrill1-345/+152
1999-03-23Automake II patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. EmailJoel Sherrill1-34/+44
description follows: Description: * automake for *all* tool subdirectories (Makefile.am, configure.in etc.) * autogen now also considers CONFIG_HEADER (generates stamp-h.ins and config.h.ins) * c/src/tests/tools/generic/difftest and c/src/tests/tools/generic/sorttimes generated by configure scripts * c/update-tools/ampolish, beautifier for Makefile.ams, similar to acpolish * rtems-polish.sh added to c/update-tools/ + ampolish support * New subdirectory ./automake, contains automake -Makefile fragments to support RTEMS make "debug, debug_install, profile, profile_install" for native Makefile.ams (== ignore these make targets). * aclocal/rtems-top.m4's RTEMS_TOP now reads the automake makefile variable VERSION from RTEMS ./VERSION file. * ./configure.in uses the macros from aclocal + support for the tools' configure scripts Remarks: * To run rtems-polish.sh, "cd <rtems-source-tree>; ./c/update-tools/rtems-polish.sh" * AFAIS, now all native subdirectories are converted to automake (Please drop me a note, if I forgot something). * Unless you notice something fatal, IMO the time has come for a public try (== snapshot). I do not intend to send more automake related patches within, say 2 weeks, to give these patches time to settle and to give me some time to think on how to continue. * The patch assumes installation to the new main installation directory [$(prefix)].
1999-03-19Incorporated automake I patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-0/+1622
This is the first real automake patch. It adds automake support to c/build-tools and cleans up a few minor issues. I consider this to be a testing probe to examine problems with automake. Therefore, this patch is just a more or less harmless replacement of the former RTEMS Makefiles and I expect it not last for long. If you want to give automake Makefiles a public try and if you want/need to learn about problems with it, then it's about time for a new snapshot, IMO. I may have screwed up something not directly related to automake, but I expect very few (none to be precise) problems with automake. However, somebody should at least try building on Cygwin. If you feel a bit more adventureous, then I also can continue to submit more patches. [FYI: I still have a couple of automake files laying around, but they need some cleanup before being submitted as patches. Now, that I am just into it, I'll perhaps submit another one tonight :-] After applying this patch (patch -p1 -E < <path-to>/rtems-rc-19990318-0), first run the "autogen" script from the toplevel source directory, before committing to CVS. Be careful about dependencies between Makefile.am and Makefile.ins when cutting tarballs from CVS. Makefile.ins are required to be newer than Makefile.ams, otherwise users would need to have automake, autoconf and perl. Some people recommend to "touch" all Makefile.in after checkout from cvs (cf. egcs/contrib/egcs_update). ATTENTION: * This patch adds a number of new files. * remove aclocal/exeext.m4 and aclocal/cygwin.m4 from CVS, They are now covered by autoconf-2.13`s AC_EXEEXT. Some features/side-effects which are probably interesting for you: In a configured build-tree "cd c/build-tools", then try * "make RTEMS_BSP=<bsp> install" * "make RTEMS_BSP=<bsp> dist"
