like signal dispatching.
correct Information block.
incorporate variable length object names. Previously the algorithm
scanned an array of 4-byte names for a match. Now it scans the
object table, grabs a pointer to the name, and then compares it
if the object is active and has a name.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
blocking mechanism for it.
