* src/objectgetbyindex.c: Do not enable dispatching on an
error path it was not disabled on.
* src/Makefile.am: Include compile.am.
code remaining here now only blocks.
dispatching -- disabled.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
converted to automake.
were done by Joel.
and _CORE_message_queue_Insert_message for posix message queues.
+ Yellow line tested new source
+ Yellow lined tested routine with Posix message queue test (01)
and his EPICS porting effort.
_Object_Extend_information. This change is a side-effect of the
change made to that file to fix an alignment problem.
being allocated. This bug manifested itself on the SPARC
since it uses ldd/std in its context save/restore routines.
based thread queue were to be reinserted based on its new priority,
this is where the logic would go.
by ITRON.
Corrected spacing.
support for return codes from POSIX threads that do an implicit exit
by returning from the bottom of the main function.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
Problem: a posix thread which is created by
pthread_attr_init(&tattr);
pthread_attr_setinheritsched(&tattr, PTHREAD_EXPLICIT_SCHED);
pthread_attr_setschedpolicy(&tattr, SCHED_RR);
pthread_create(&th, &tattr, func, arg);
has a first timeslice of 2^32 ticks (changing a running thread to
SCHED_RR id ok).
I use RTEMS-4.0.0. I am not sure if the problem exists in the current CVS
head revision. If it's not fixed, the patch at the end should do it.
Peter
--- pthreadcreate.c.orig Wed Jul 28 14:45:58 1999
+++ pthreadcreate.c Wed Jul 28 15:06:09 1999
@@ -199,6 +199,10 @@
api->schedpolicy = schedpolicy;
api->schedparam = schedparam;
+ if ( schedpolicy == SCHED_RR ) {
+ the_thread->cpu_time_budget = _Thread_Ticks_per_timeslice;
* This insures we evaluate the process-wide signals pending when we
* first run.
