to be able to build a system without requiring printf.
are automatically activated upon insertion.
WATCHDOG_BEING_INSERTED.
Thread_Close fixed to avoid returning FP context area when one was not
allocated at initialization time.
Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
correct Information block.
incorporate variable length object names. Previously the algorithm
scanned an array of 4-byte names for a match. Now it scans the
object table, grabs a pointer to the name, and then compares it
if the object is active and has a name.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
blocking mechanism for it.
