split into one function per file, this will decrease the size of executables.
<ccj@acm.org> of Objective Design Systems.
future.
cd <rtems-source-tree>
joel@OARcorp.com wrote:
> Chris,
> sp09 fails on the rtems_port_delete(0) call. This is supposed to give an
> invalid id error. I can't find any changes other than the unlimited
> objects patch which would have tripped this so would appreciate it if you
> could look into it. I suspect that this is a side-effect of the unlimited
> objects patch.
It is me.
> Basically, there are 0 ports configured in sp09. The test ends up
> dereferecing NULL in local_table[0] and comes up with a non-NULL invalid
> pointer.
The issue is not actually allocating a local_table for an object type
which has a maximum value of 0. I cannot remember the exact workings of
the id values and the local_table. I might have changed the nature from
the pre-unlimited change. As you know the id's are an interesting game
where performance is most important.
> I know the problem could be solved by adding a check for index == 0. But
> I hate to slow this path down. I think you may have changed the way the
> object information structure gets initialized.
---- CVS log ----
This change lets the unlimited and sp09 tests run on the posix Linux
BSP. A static local variable `null_local_table' has been added. This
variable is always set to NULL. The `**local_table' element of the
information structure is set to point to this variable earily in the
initialisation. If the object type has more than 0 elements the
`local_table' element is updated. All object types which have 0 elements
reference `null_local_table'. This change fixes the problem sp09 found
yet does not add any extra processing to the critical
`_Objects_Get_local_object' function.
---- CVS log ----
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
are:
it work.
1) Socket timeout field changed from `short' to `long'. This makes longer
timeouts possible. With a 1 kHz system clock the old system allowed
timeouts only up to a little over 30 seconds! This change is a
slightly cleaned-up version of the patch proposed by Ian Lance Taylor.
2) Major changes to BOOTP/DHCP reply handling. Now supports much of
RFC2132. These changes were done at the request of, and with the
assistance of, Erik Ivanenko.
If you're making changes, you might want to change the network
supplement Essentially just do a global search and replace of BOOTP
with BOOTP/DHCP.
ports.
when building the executive source.
not use priority ceiling or priority inheritance protocols.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
software floating point emulation code. Code implemented by
Karen Sara Looney <Karen.Looney@colorado.edu> with much
email assistance from Joel.
be resolved.
argument indicates whether the task is to be placed at the head or tail of
its priority fifo when it is lowering its own priority. POSIX normally
follows the RTEMS API conventions but GNAT expects that all lowering of
a task's priority by the task itself will result in being placed at the
head of the priority FIFO. Normally, this would only occur as the result
of lose of inherited priority.
compiler.
hardcoded 4 to be compatible with CPUs with 64-bit ints
FIFO and priority disciplines.
context of the first thread to execute.
MP_packet_Classes
checks to ensure priority was not lowered.
switch. This was needed to support process wide signals.
in the core to support multiple algorithms to handle cpu time budgetting
which resulted in a change to the calling sequence of _Thread_Initialize.
_Thread_Ticks_remaining_in_timeslice.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
_ISR_Enable() takes the magic cookie expected by the cpu's status register
instead of a simple isr level.
routine.
