path: root/c/src/exec/score/src/wkspace.c (follow)
* loop to clear workspace memory changed to use sizeof rather thanJoel Sherrill1996-09-181-1/+1
| | | | hardcoded 4 to be compatible with CPUs with 64-bit ints
* thread.c: added support for optional user provided stack allocatorJoel Sherrill1996-04-221-0/+43
| | | | wkspace.c: made initialization routine a regular subroutine
* posix support initially addedJoel Sherrill1995-09-261-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-3/+7
* Fixed missing RCS IdsJoel Sherrill1995-08-221-1/+1
* bug fixes to make macro implementations workJoel Sherrill1995-08-161-10/+2
* TESTJoel Sherrill1995-05-251-0/+2
* Initial revisionJoel Sherrill1995-05-111-0/+47
