path: root/c/src/exec/score/src/watchdog.c (follow)
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-011-7/+5
| | | | are automatically activated upon insertion.
* Corrected use of the state WATCHDOG_REINSERT and renamed itJoel Sherrill1995-12-011-6/+19
| | | | WATCHDOG_BEING_INSERTED.
* posix support initially addedJoel Sherrill1995-09-261-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-7/+7
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-20/+51
* Initial revisionJoel Sherrill1995-05-111-0/+225
