path: root/c/src/exec/score/src/watchdog.c (follow)
* Fixed spacing.Joel Sherrill1998-01-061-2/+2
* renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the WatchdogJoel Sherrill1996-05-311-0/+6
| | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency.
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-011-7/+5
| | | | are automatically activated upon insertion.
* Corrected use of the state WATCHDOG_REINSERT and renamed itJoel Sherrill1995-12-011-6/+19
| | | | WATCHDOG_BEING_INSERTED.
* posix support initially addedJoel Sherrill1995-09-261-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-7/+7
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-20/+51
* Initial revisionJoel Sherrill1995-05-111-0/+225
