path: root/c/src/exec/score/src/threadq.c (follow)
* Split Heap and Time of Day Handlers.Joel Sherrill1999-11-021-913/+0
* Split threadq.c into multiple files.Joel Sherrill1999-11-021-0/+2
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-3/+19
| | | | it work.
* more comments added and existing ones cleaned up in synchronization pathsJoel Sherrill1996-02-131-1/+13
* new isr synchronization algorithm using a single enumerated set of states.Joel Sherrill1996-02-091-42/+73
* synchronization state bugs addressJoel Sherrill1996-02-011-7/+12
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-011-5/+1
| | | | are automatically activated upon insertion.
* Added new synchronization algorithm.Joel Sherrill1995-12-011-58/+92
* posix support initially addedJoel Sherrill1995-09-261-7/+7
* More file movementJoel Sherrill1995-09-211-2/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-32/+40
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-37/+83
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Initial revisionJoel Sherrill1995-05-111-0/+837
