path: root/c/src/exec/score/src/threadinitialize.c (follow)
* Fix after this report from Peter Pointner <pr@schenk.isar.de>:Joel Sherrill1999-07-281-0/+12
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Problem: a posix thread which is created by pthread_attr_init(&tattr); pthread_attr_setinheritsched(&tattr, PTHREAD_EXPLICIT_SCHED); pthread_attr_setschedpolicy(&tattr, SCHED_RR); pthread_create(&th, &tattr, func, arg); has a first timeslice of 2^32 ticks (changing a running thread to SCHED_RR id ok). I use RTEMS-4.0.0. I am not sure if the problem exists in the current CVS head revision. If it's not fixed, the patch at the end should do it. Peter --- pthreadcreate.c.orig Wed Jul 28 14:45:58 1999 +++ pthreadcreate.c Wed Jul 28 15:06:09 1999 @@ -199,6 +199,10 @@ api->schedpolicy = schedpolicy; api->schedparam = schedparam; + if ( schedpolicy == SCHED_RR ) { + the_thread->cpu_time_budget = _Thread_Ticks_per_timeslice; + } + /* * This insures we evaluate the process-wide signals pending when we * first run.
* Thread Handler split into multiple files. Eventually, as RTEMS isJoel Sherrill1999-05-171-0/+175
split into one function per file, this will decrease the size of executables.
