path: root/c/src/exec/score/src/object.c (follow)
* Split object.c into multiple files.Joel Sherrill1999-11-021-982/+0
* Fixed bug which resulted in misaligned object control structuresJoel Sherrill1999-11-021-3/+5
| | | | | being allocated. This bug manifested itself on the SPARC since it uses ldd/std in its context save/restore routines.
* Added code to allocate by index. This is the object ID style usedJoel Sherrill1999-11-021-27/+134
| | | | | | by ITRON. Corrected spacing.
* Patch from Chris Johns <ccj@acm.org>:Joel Sherrill1999-03-311-5/+13
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | joel@OARcorp.com wrote: > > Chris, > > sp09 fails on the rtems_port_delete(0) call. This is supposed to give an > invalid id error. I can't find any changes other than the unlimited > objects patch which would have tripped this so would appreciate it if you > could look into it. I suspect that this is a side-effect of the unlimited > objects patch. > It is me. > > Basically, there are 0 ports configured in sp09. The test ends up > dereferecing NULL in local_table[0] and comes up with a non-NULL invalid > pointer. > The issue is not actually allocating a local_table for an object type which has a maximum value of 0. I cannot remember the exact workings of the id values and the local_table. I might have changed the nature from the pre-unlimited change. As you know the id's are an interesting game where performance is most important. > > I know the problem could be solved by adding a check for index == 0. But > I hate to slow this path down. I think you may have changed the way the > object information structure gets initialized. > ---- CVS log ---- This change lets the unlimited and sp09 tests run on the posix Linux BSP. A static local variable `null_local_table' has been added. This variable is always set to NULL. The `**local_table' element of the information structure is set to point to this variable earily in the initialisation. If the object type has more than 0 elements the `local_table' element is updated. All object types which have 0 elements reference `null_local_table'. This change fixes the problem sp09 found yet does not add any extra processing to the critical `_Objects_Get_local_object' function. ---- CVS log ----
* Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows:Joel Sherrill1999-03-171-81/+483
| | | | | | | | | | | | | | | | | | | | | | | | | First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you.
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-0/+12
| | | | it work.
* added some casts to reduce warnings reported by users with Microtec C++Joel Sherrill1997-01-081-16/+19
| | | | compiler.
* corrected prototype of _Objects_Get_nextJoel Sherrill1996-09-181-1/+1
* spacingJoel Sherrill1996-05-291-0/+1
* posix support initially addedJoel Sherrill1995-09-261-6/+6
* moving files aroundJoel Sherrill1995-09-211-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-25/+37
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-0/+22
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-3/+11
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-29/+187
* Modified object name to id translation loop to make it easier toJoel Sherrill1995-08-221-16/+24
| | | | | | | incorporate variable length object names. Previously the algorithm scanned an array of 4-byte names for a match. Now it scans the object table, grabs a pointer to the name, and then compares it if the object is active and has a name.
* + Added object type field to object id.Joel Sherrill1995-08-181-10/+19
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+67
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-111-0/+228
