path: root/c/src/exec/score/src/mpci.c (follow)
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-0/+2
| | | | it work.
* added some casts to reduce warnings reported by users with Microtec C++Joel Sherrill1997-01-081-1/+1
| | | | compiler.
* _MPCI_Register_packet_processor: changes first parameter type to ↵Mark Johannes1996-08-081-1/+1
| | | | MP_packet_Classes
* Added Sporadic Server support to posix threads which required changesJoel Sherrill1996-06-061-1/+2
| | | | | in the core to support multiple algorithms to handle cpu time budgetting which resulted in a change to the calling sequence of _Thread_Initialize.
* Removed the internal thread objects and dispersed its contents toJoel Sherrill1996-02-211-2/+181
| | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized.
* added correct use of _Thread_queue_Enter_critical_sectionJoel Sherrill1995-12-081-1/+1
* posix support initially addedJoel Sherrill1995-09-261-12/+12
* More file movementJoel Sherrill1995-09-211-4/+3
* moving files aroundJoel Sherrill1995-09-211-1/+1
* Initial attempt at building HP PA-RISC using Solaris hosted tools.Joel Sherrill1995-09-121-1/+1
| | | | Changed back to Newlib for Solaris UNIX simulator.
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-37/+144
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-2/+4
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Initial revisionJoel Sherrill1995-05-111-0/+237
