it work.
not use priority ceiling or priority inheritance protocols.
argument indicates whether the task is to be placed at the head or tail of
its priority fifo when it is lowering its own priority. POSIX normally
follows the RTEMS API conventions but GNAT expects that all lowering of
a task's priority by the task itself will result in being placed at the
head of the priority FIFO. Normally, this would only occur as the result
of lose of inherited priority.
FIFO and priority disciplines.
checks to ensure priority was not lowered.
like signal dispatching.
