path: root/c/src/exec/score/src/coremutex.c (follow)
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-301-1/+3
| | | | | | | | | | | | | * src/coremutex.c, src/coremutexseize.c, src/coremutexsurrender.c, inline/rtems/score/coremutex.inl: The per thread field resource_count should only be manipulated when a mutex is priority ceiling or priority inherit. This was reported by Chris Johns <ccj@acm.org> who also noticed that the use of switches for all disciplines generated less efficient code than using explicit tests for the one or two cases we were really interested in. Further review of his modifications made it apparent that the "isa" methods to test mutex discipline were not being used so this modification was swept into the code as well.
* Added blocked_count field to allow for optimizations.Joel Sherrill2000-07-031-2/+3
* Added support for simple binary semaphores in addition to the highJoel Sherrill2000-01-051-1/+12
| | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority.
* Split core message queue and watchdog handler objects into separate files.Joel Sherrill1999-11-021-269/+0
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-1/+4
| | | | it work.
* Modified to make it possible for an ISR to return a mutex which didJoel Sherrill1998-02-201-2/+20
| | | | not use priority ceiling or priority inheritance protocols.
* Modified calls to _Thread_Change_priority to take a third argument. The newJoel Sherrill1997-03-081-7/+9
| | | | | | | | | argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority.
* Reversed logic in conditional to correctly distinguish betweenJoel Sherrill1996-09-171-2/+2
| | | | FIFO and priority disciplines.
* fixed spacingJoel Sherrill1996-08-131-2/+2
* _CORE_Mutex_seize: added checks for priority ceiling violation, also addedMark Johannes1996-08-071-6/+24
| | | | checks to ensure priority was not lowered.
* _CORE_mutex_Seize: added change priority case if the mutex was obtained.Mark Johannes1996-08-061-0/+12
* added priority ceiling supportJoel Sherrill1996-06-031-32/+61
* Swapped order of nested acquisition check and check for returning unsatisfied.Joel Sherrill1996-02-011-6/+6
* added correct use of _Thread_queue_Enter_critical_sectionJoel Sherrill1995-12-081-1/+1
* posix support initially addedJoel Sherrill1995-09-261-5/+5
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-0/+269
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
