future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
are:
automake:
* I didn't yet touch the cpu subdirectory. I still need some time to
think on how to handle them.
* I probably will wait for the next snapshot before mailing more patches
(I still have some pending), giving you a chance to apply them and me a
chance to become target of the bullets which will probably be aimed at
me after these modifications.
it work.
not a valid object class. This was discovered while looking for
a bug reported by Jennifer.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
as the sole statement in an if or else statement
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
in each thread which must be set when the post switch extension is to be run.
like signal dispatching.
correct Information block.
(andy@i-cubed.demon.co.uk). This initial submission is known
to work on the IBM 403. It is thought to work on the Motorola
601, 603, and 604 although this remains to be tested.
Another user -- Doug Currie (e@flavors.com) -- is interested in
this work and will be testing it on the 604 using the Metrowerks
C compiler and a different format assembly language.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
