like signal dispatching.
(andy@i-cubed.demon.co.uk). This initial submission is known
to work on the IBM 403. It is thought to work on the Motorola
601, 603, and 604 although this remains to be tested.
Another user -- Doug Currie (e@flavors.com) -- is interested in
this work and will be testing it on the 604 using the Metrowerks
C compiler and a different format assembly language.
