path: root/c/src/exec/score/macros/heap.inl (follow)
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* Modifications from Tony Bennett accepted to return aligned block.Joel Sherrill1995-09-191-0/+12
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-221-1/+1
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* bug fixes to make macro implementations workJoel Sherrill1995-08-161-1/+3
* Initial revisionJoel Sherrill1995-05-111-0/+136
