path: root/c/src/exec/score/inline (follow)
* Removed duplicate lines in file.Joel Sherrill1999-01-191-14/+0
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> heading towardJoel Sherrill1998-12-162-0/+28
| | | | | | | | | | | | automake: Notes: * I didn't yet touch the cpu subdirectory. I still need some time to think on how to handle them. * I probably will wait for the next snapshot before mailing more patches (I still have some pending), giving you a chance to apply them and me a chance to become target of the bullets which will probably be aimed at me after these modifications.
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-232-4/+12
| | | | it work.
* Fixed typo.Joel Sherrill1998-07-012-2/+2
* Modified _Objects_Is_class_valid() to correctly report that 0 wasJoel Sherrill1998-06-182-2/+2
| | | | | not a valid object class. This was discovered while looking for a bug reported by Jennifer.
* Per suggestion from Eric Norum, went from one initial extension setJoel Sherrill1998-04-152-4/+26
| | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence.
* updated copyright to 1998Joel Sherrill1998-02-1742-42/+42
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-302-8/+4
* Removed warning per Chris Johns' suggestion.Joel Sherrill1998-01-202-2/+2
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-202-2/+2
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-102-2/+8
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0842-84/+84
* Removed include directory at "build" point and the link of this directoryJoel Sherrill1997-10-082-2/+2
| | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable.
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2242-210/+210
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-012-0/+62
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* changed _TOD_Is_set from a function to a boolean variableJoel Sherrill1996-09-062-30/+0
* removed Thread_queue_Get_number_waitingMark Johannes1996-08-132-32/+0
* switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1996-07-0342-348/+348
* renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the WatchdogJoel Sherrill1996-05-312-2/+2
| | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency.
* made initialization routine a regular subroutineJoel Sherrill1996-04-222-94/+0
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-0642-6/+1502
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* Removed the internal thread objects and dispersed its contents toJoel Sherrill1996-02-212-0/+48
| | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized.
* changed post task extension from user set to api set and added flagJoel Sherrill1996-02-132-48/+0
| | | | in each thread which must be set when the post switch extension is to be run.
* new isr synchronization algorithm using a single enumerated set of states.Joel Sherrill1996-02-092-2/+0
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-156-10/+26
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-014-32/+12
| | | | are automatically activated upon insertion.
* Added support for new synchronization algorithm. Specifically, the routineJoel Sherrill1995-12-012-0/+28
| | | | _Thread_queue_Enter_critical_section was added.
* SPARC port passes all testsJoel Sherrill1995-10-304-12/+74
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-292-4/+4
* posix support initially addedJoel Sherrill1995-09-268-4/+86
* Modifications from Tony Bennett accepted to return aligned block.Joel Sherrill1995-09-192-0/+32
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-0/+372
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1132-454/+516
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-288-20/+46
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-232-12/+46
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-76/+14
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-222-2/+2
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* + Added object type field to object id.Joel Sherrill1995-08-182-10/+48
| | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control.
* bug fixes to make macro implementations workJoel Sherrill1995-08-162-42/+2
* Fully tested on all in-house targetsJoel Sherrill1995-05-242-70/+0
* Initial revisionJoel Sherrill1995-05-1136-0/+5388
